Question about Sony Cyber-shot DSC-S730 Digital Camera
Camera Lens stays popped out and won't turn on
It will turn on for like 2 seconds and then switch off
  • 71 Answers
Recharge or repace batteries. Use good quality batteries for Digital cameras.
Posted on Jun 17, 2009
Camera won't stay on making funny noise lens won'tpop out
your lens is stuck up,making camera hesitate to turn on. may be dirt sticked on it. have it cleaned carefully and retry. regards
Sep 30, 2011 | Kodak EasyShare Z650 Digital Camera
Nikon d80 won't turn off. Stayed on after viewing slide show on TV. Operates properly with switch in "off" or "on" position. Tried:1. removing battery. it restarts with switch...
It may be as simple as a broken or worn out on/off switch. If the switch shorts out, the camera will always be on or always be off. The problem could also be the switching circuitry. If you need service, you should call Nikon's Service Department at 1-800-NIKON-US (1-800-645-6687)9AM-8PM EST, Monday to Friday.
Sep 20, 2011 | Nikon D80 Digital Camera with 18-200mm...
Camera lens wont open
Saw a similar problem recently, same cause, and result was the lens was jammed.
Did manage to wiggle it free after many attempts...it only stays on for a few seconds before faulting and going off...but it's a bit hard to get a hold on the edge of the lens to pop-out the low side.
Started by laying it on it's back and checking the level of the lens edges for the low spot, then used a thick sewing needle to lift up while turning the unit on (again and again) until the gear-ring popped back in during the lens-check at start-up.
Apr 06, 2010 | Casio Exilim EX-Z40 Digital Camera
COMING ON BUT SWITCHING OFF WITHIN SECONDS EVEN
You may check whether your lens is popped out or not. If your lens is keep popped out then there are chances that your Shuttle is locked inside the camera.
Solution is need to replace the Shuttle, and it may possible that you gently (accidentaly) pushed/press the lens.
Regards Rushi
Feb 18, 2010 | Olympus D-545 Zoom Digital Camera
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
It suddenly crashed so I took the battery out. Now it does nothing except beep when I turn it on and the screen stays black! Help!!!1
The lens is stuck. Switch on and tap the edge of the camera against your hand quite sharply. The lens should eventually pop out and screen operate as normal. Make sure lens casing is totally clean before switching off.
Cheers
Paul
Aug 10, 2009 | Samsung L200 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
The Lens wont pop out
Dear
Most probably your battery is low, if not then control circuit has been malfunctioned. Sorry
Jan 30, 2009 | Kodak EasyShare V1233 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
