Question about Singer Tiny Tailor TT700
Prolems getting bobbin thread to lock in order to sew,
How do I fix problem? Have checked all with manual.
  • 136 Answers
Give up and get a real machine, no one will even touch that tiny tailor
Posted on Jun 18, 2009
Bobbin not functioning in my sewing machine.
Consult your owner's manual. It sounds like possibly you don't have the bobbin threaded in the bobbincase properly. The bobbin must spin (either clockwise or counterclockwise per the manual) a certain direction and the thread needs to be threaded in the bobbincase in order for the bobbin to turn.
Sep 05, 2015 | Sewing Machines
Euro pro 9130 Bobbin holder jumps out of place when sewing, then the machine locks up, tweets and stops sewing. I have ordered a new bobbin holder and that did not help.
check the upper thread tension
make sure all the thread guides all used- & that the thread is not hanging up some where on the machine
check the top thread tension dial to see if there is any thread caught in it
change the top & bobbin thread- make sure the thread is not knoty or old
Mar 12, 2012 | Euro-Pro 9130 Sewing Machine
I would like to learn how to clean and oil my Kenmore model 19365 sewing machine plus any other routine maintainence. I also am having prolems with my bobbins not staying in the bobbincase while sewing. I...
If, I were you I would take my machine to the Sears sewing machine department and ask the salesperson how to do these things. They are usually very helpful, and if you need a manual they can order it for you. Do not be afraid to ask for help because just remember the only dumb question is the one that isn't asked.
Dec 28, 2010 | Kenmore 19365 Computerized Sewing Machine
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
The bobbin thread does not fully rotate in the bottom in order to catch the top thread. The bobbin thread stops halfway... looks like the hook is not catching the thread properly. How do I fix that?? (This...
Is there thread caught in the bobbin case? How far are you turning the wheel and are you holding the end of your bobbin thread out so that the top thread can hook it?
Nov 22, 2009 | Brother Sewing Machines
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Mar 06, 2009 | Necchi 3102 Mechanical Sewing Machine
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
357 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
