Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
The picture is all shaky and flickers black an white. It wont show my xbox 360 picture clearly with standard or hd and doesn't show my cable stations at all in standard, can any body help me with a solution?
    Genius:
  • 1,030 Answers
From your decription i would guess that you have a bad hyper module ideally you need to replace this but their hard to find. so toshiba has issued repair instructions for repair of this board which involves replacement of very small micro capacitors. our shop ussally charges around 200 for this repair. this is not a easy repair you need experience tech to solder becuse you can easly damage this nonreplaceable board
Posted on Jun 17, 2009
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 video failure
If you want to save yourself some money don't send it to microsoft. They just do a temp. fix. Go on you tube and look up x-clamp fix. Trust me if you do it right your console will be fixed.
Jun 15, 2009 | Microsoft Xbox 360 Console
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
Un recognisable picture
try a different set of av cables and or input on the tv and see what u get
Jun 21, 2008 | Microsoft Xbox 360 Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
289 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
