Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
D-Link 615 stopped connecting with wireless
I have setup my router 2 days ago and it installed perfectly. Yesterday evening it stopped connecting to wireless. It still wired but I need wireless to be able to work in my bedroom away from the family. I have a new Toshiba laptop running vista. Not a computer genius . Help!
    Sergeant:
    Champion:
  • 310 Answers
If your laptop is not detecting the wireless router, can you try to get the laptop closer to the router ? If you have done that already, I would suggest you to try and power cycle the router once. If that doesnt work either, try to reset the router. Hope this helps
Thanks Ranjit ranjit@supportminds.com
Posted on Jun 17, 2009
How can i fix dir 615 ssid stop broadcasting issue?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password
Step 3: Under Setup Select the Wireless tab
Step 4: On Wireless Tab - Select Invisible if you do not want the SSID of your wireless network to be broadcasted by the DIR-615. If Invisible is selected, the SSID of the DIR-615 will not be seen by Site Survey utilities so your wireless clients will have to know the SSID of your DIR-615 in order to connect to it.
Sep 08, 2014 | D-Link DIR-615 Wireless Router
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
I have a D Link WBR 1310 router. Is this outdated and would it solve my intermittend internet service if I should upgrade?
The d link wbr 1310 is end of life in the us as of may 1 2011. I have a dir-615 that I stopped using 2 years ago b/c of connection problems and I believe the dir-615 is newer. I think you should upgrade.
Jul 24, 2011 | D-Link DIR-615 Wireless Router
I have a DIR 615 Dlink wireless router connected to a Dell computer running XP Pro. Checked for latest firmware, had it. About every 2 or 3 days it will stop broadcasting a signal and I can not logon with...
Ok this might be a bit tricky but it sounds like there is another wireless signal that may be interfering with yours.
Do you have an older cordless phone in the house? If so try and move the cordless base farther away from the wireless router. Even if they are on different floors in your house, if they are located near each other the cordless can interfere with the wireless signal.
The other possibility is that there is signal that is coming from the outside of your location and is causing the interference.
I know that when I had an XP Pro machine (Laptop) it would drop the wireless signal every couple of days or so. I traced my problem to my neighbors cordless phone. he had an old one and it was near the side of my house that my router was on and it was causing me problems so I move my router and the problem went away.
hope this helps
May 21, 2011 | D-Link DIR-615 Wireless Router
My problem is i have 2 pcs,.the main pc has a wireless d-link router and a modum with internet connected.im trying to connect my new d-link 615 to the other pcwhich has no internet.ive follwed all the...
I was facing a similar issue a while ago when I stumbled upon www.ijinni.com. The site was exceptionally well laid out and easy to navigate. All I had to do is, pose my question. The resolution was provided very promptly. They offer some excellent technical guidelines which cover a wide range of topics from installing network drivers to cleaning your mouse JUST FOR $10. So if you are looking for online technical support for any kind of computer related issues with knowledgeable specialists who come up with perfectly acceptable solutions, www.ijinni.com is the right pick.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just add the contact "ijinni.com" (free call).
3. You can email at support@ijinni.com
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call IJINNI
Clean, straightforward and effective!
Mar 27, 2011 | D-Link DIR-615 Wireless Router
The router is not connecting to the internet. The internet works perfectly fine but when I plug the ethernet cord into the router it wont work.
Check your computer setup. The ethernet port has to activated on your computer for it to get the router output. This is usually accomplished by going into your BIOS setup and turning it on, that is if you installed the driver during the initial setup of the computer.
Jan 05, 2011 | D-Link DIR-615 Wireless Router
I have 2 laptops one is dell and one toshiba. I installed new router dlink 615 and I am connected on toshiba but not with dell. What might be the problem?
Check for the IP settings, ensure that they are in sync with the settings of your router. For example, setup your computer to use automatically provided IP if your router assigns one; otherwise else push a manual/static IP.
Feb 02, 2010 | D-Link DIR-615 Wireless Router
Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Nov 24, 2009 | D-Link DIR-615 Wireless Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
121 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
