Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Power on 2 sec. then off won't turn mitsubishi wt-42313
I push power button green light comes on for 2 sec. then clicks off how do I fix the probem ?
    Problem Solver:
  • 13 Answers
With this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Posted on Jun 17, 2009
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
My TV not powering on. It clicks and power lightgoes green, then
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 06, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power light for 2 seconds, then nothing:
send me d model number and i could help most likely u have a powersupply problem
Apr 07, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
244 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
