Question about Carrier Heating & Cooling
I am getting Circuit A and B suction transducer failure alarms I've replaced both transducers. Ive got 5vdc from red to blk and from green to red at the senser.The pressure reads 0psig on the marquee and then switches to ''140 psig Fail'' when the alarm comes on.(Which is before the compressors can even start. Then after 2hrs the compressors start up on its own even though the alarm was not reset. I turned off at the disconnect nine identical rtu's units for filter changes. 3 of the nine gave me this transducer failure problem. 2 started back up after several alarm resets The 3rd is being much more stubborn. Also of the 36 scroll compressors at this sight 2 have been replaced due to a sputtering sound they make when they are shut off. 3 months later the replacement compressors are now sputtering. Keep in mind they are in a twin compressor arrangement. I am getting a reverse rotation alarm on one of them and then the unit shuts off. I reversed the phases for the hell of it and got the same result. Sure could use some feed back.
  • 334 Answers
Hey there, let's see if I can shed some light on your situation for ya. First of all, those noisy compressors are from the refrigerant feeding back through at shut off. Chances are, these are the compressors with the built in check valves and if they were replaced and doing it again makes you wonder if something is breaking them down. Also, if the are running at a real high pressure, the compressors may have enough pressure in them in front of the check valve to make them spin bckwards at shutdown. If it is two tandem compressors, I would vote for the latter. As far as the pressure xducers, I have never heard of that issue before after turning off and back on. I do know that the way carrier looks at its sensors is one at time and if one sensor is shorted, it will pull the voltage down and whichever sensor carrier is looking at at that particular time will show as a failure even though that one may not be bad. The way to identify this is to clamp on the pressure xducer wires with your meter and set it to min/max. If there is a short, your meter should go to zero (set on min). This will ell you there is a short somewhere, just up to you to find it. Let me know if this doesn't help or you need anything else
Posted on Jun 17, 2009
Ingersoll rand ssr200 shut down with alarm 4apt what is this code
The 4apt alarm is telling you that there is a problem with the 4apt pressure transducer. It may need calbrating which is doubtful. From the limited info I would guess the transducer has gone bad and should be replaced.
Sep 23, 2013 | Ingersoll Rand Air Tools & Compressors
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
The bass of my wowee one doesn't work anymore
The problem is most likely a broken solder connection on the the voice coil side of the bass transducer. I just repaired one and it was a 5 minute fix if you have a small soldering iron. Carefully pry off the glossy plastic cover where starting with the side the speaker slits (grill) are. It's just held in with some sticky adhesive (peel it up slowly, allowing the glue to separate without cracking the cover). Below that cover are 6 phillips screws. Unplug bass transducer's wire harness from the circuit board. IThe white connector comes apart with a small tug. The other end of the wire harness goes to the round, green transducer's board which contains the voice coil. Remove the transducer assembly (the round thing with with the clear Gel like substance). Carefully remove the gel surround and separate the round circuit board from the round magnet. One of the black or red wires will probably be disconnected. This is probably due to the a bad solder connection coupled with the constant vibrations. Simply re-solder the connection and re-assemble and you're good to go. When re-asembling the transducer, be sure to install the round board first and make sure it slips UNDER the raised lip inside of the Gel. If installed correctly the whole bottom of the round green board will be in full contact to the gel. Now install the magnet. The magnet should rest on TOP of the gel lip inside, the lip keeps the magnet raised slightly above the board and allows it to vibrate freely without touching the the round board and the voice coil (brown colored wire winding attached to green board. Hope this helps.
Mar 22, 2012 | Audio Players & Recorders
I've purchased an Eagle 320 fishfinder 2 years ago and I've had to replace my transducer twice. Every time I'm out fishing lakers in 50 to 100 feet of water, I keep loosing the bottom mark and...
I have never heard of Eagle Fishfinders, but I would be inclined to package it up and send it back to them for checking under warranty, with a fault that should never happen. The brand leaders are Lowrance and Humminbird, with Garmin in 3rd place.
I have a Humminbird 998HD with Side Imaging. I had a 798SI before that and never a problem. the 998 cost me nearly 2 grand Canadian and is used on Lake Ontario, twice a week every week from May to October, and has been faultless. The 798 was used from 2008 to 2014 and also faultless. I think you have a 'Friday Special'.
Mar 14, 2017 | Eagle Fishmark 320 Portable Fishfinder
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
Mounting a transducer on a canoe
I used a suction cup with a bracket to attach the transducer.The suction cup is attached to a rope and when landing just pull.
Aug 30, 2009 | Garmin Fishfinder 140
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Heating & Cooling Logo
335 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
