Question about HP Officejet 5610 All-In-One InkJet Printer
Won't pick up fax line automatically - HP Officejet 5610 All-In-One InkJet Printer
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab104
Posted on Jul 17, 2009
I have canon MF 5750 that I get some faxes and not others and they are not in memory.
Posted on Jun 17, 2009
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
How to receive a fax
  1. Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to receive fax
Instructions Things You'll Need:
  • Phone line
  • Multi-function printer
  1. Step 1 Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Step 2 Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Step 3 Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Step 4 Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Step 5 Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Step 6 Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Step 7 Set the desired print quality, and you are ready to receive faxes.
You should be all set now to receive faxes.
Aug 06, 2010 | HP Officejet 4355 All-In-One InkJet...
Fax machine won't receive without pick up phone receiver.
on the front display you will see a recieve button and you need to press this and you will see on the display it say either fax...fax/tel.. auto press the button until fax shows thsi means it is only being used as a fax so the line will auto pick up... if you set it to auto it will ring check the line and if it finds its a fax it will put it through as one if not it will ring you phone.. good luck
Jun 26, 2009 | Brother IntelliFax-4100e Fax
How could I switch the fax, to receive
do you mean the fax line is shared with the phone line, and you want the machine to pick up faxes when necessary, and let phone calls go? If that's the case, this mahcine is designed to be on a dedicated line. In other words, there is not setting for "distinctive ring", or to set the # of rings to pick up. It will answer any call coming in. The only thing you can do is set it to "manual receive", under "user tools", "fax features", and then you could use it for sending faxes, but it will not receive unless you switch it to fax, and press the "on hook" button.
Jun 12, 2009 | Ricoh Aficio 1232C Color Copier
How do I manually receive an incoming fax? I do not keep it on Automatic Receive because it is on my voice line, not a dedicated fax line.
When the phone rings, pick up the external handset. When you hear the fax tone come over the line press the Start button and hand up the handset.
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 31, 2009 | Minolta Office Equipment & Supplies
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
HP Officejet 5610 All-In-One InkJet Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
