Question about Zebra Z6M Plus Thermal Label Printer
I have Z6M and trying to load a color ribbon, but the machine is stating that the ribbon is out, when the black back in it works fine, Please help
  • 43 Answers
You have to search though the settings and either configure the media to auto or color.
Posted on Jun 17, 2009
I have a fargo HPD 5000 and I am getting the error 91 stating the ribbon is out..i have changed and its still showing the same error. am I doing something wrong?
Hi Camille - that is indeed the error message for "ribbon out". This has a few possible causes:
1. Make sure you have the right ribbon for the printer. The standard color (YMCK) ribbon is #084051; if dual-sided, the standard YMCKK ribbon #084052; if monochrome/black print only, that is ribbon #084060.
2. Make sure the ribbon is loaded correctly. The spools are color-coded, so make sure the orange on the ribbon spool is in placed with the orange on the carrier - ditto for the blue.
3. Make sure you've changed the "ribbon", not the "film". The ribbon has orange and blue spools; the film has yellow & green spools.
4. Make sure the ribbon is loaded properly on the carrier - it goes the "long way" around the carrier, across the silver/metal rollers.
5. Try another new ribbon - they're RFID tagged, and occasionally an RFID tag is bad, missing, or corrupted.
6. Verify you have the latest printer firmware, to ensure all ribbon manufacturing site-codes (embedded in the RFID tag) are recognized as valid for your printer.
If you have continued problems, we can help with further support, including potential repairs. Good luck!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Feb 14, 2018 | Fargo Office Equipment & Supplies
What should i do? My Fargo is shifting in color and has a weird sound when i changed the ribbon for the 4th time
Can you please follow the below steps and please get back to me.
1,Can you clean the printer very well .
2,Go to the preference image color color management the drop 3,down select non.and also check on the card size.
4,before you insert the ribbon please roll it up to were the black color start.
Aug 09, 2014 | Fargo HDP5000 Thermal Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
After ribbon change, can't print ID card background colors - only text is printed
this machine use the thermal pressure to press out ribbon and card,
so you need check
1) your new installed ribbon is original parts or fake one
2) check again your ribbon install at properate possition and move normally when printing, or reinstall it.
3) check if there is any gap which will lost the presure balnace betwwen printer head and pressure base.
just give you some idea, send any question please
hope you fix it.
May 21, 2009 | Datacard Group SP75 Color Card Printer
Only one drive showing out of two
Hi the cable ribbon is color coded. the blue should be connected to motherboard and the gray is a slave and the black is master. Check if you have this connected properly. If you got a Cable ribbon not color coded. The cable ribbon from motherboard connector about a 12 inches long from middle slave connector and 6 inches to the master connector. If this is not connected properly and HDD is not assign slave and master most likely the OS can not detect the HDD. The other way to check is to access your bios setup if the slave and master HDD is detect. Your PC have a capability of plug and play if you connect the hardware right and load the driver. Hope this info will help you to solve the problem.
HH
Apr 20, 2009 | ASUS (M2NGREEN) Motherboard
Thermal Printer Problem
We use Nice Labels software in house and it uses the standard windows printer drivers. A good alternate site for printer drivers is seagullscientific.com.
Any further driver probs, contact me at www.lancerlabels.co.uk
trevor
Dec 15, 2008 | Zebra Z6M Thermal Label Printer
Display
does the screen settle down one the machine has booted?
Had similar problem on two Sony laptops I recently supplied, went back for warranty repair one month after purchase. Apprently turned out to be loose ribbon connecter to the panels.
If you need any more help please ask.
Regards
Nick
Jul 19, 2008 | Toshiba Satellite M115-S1061 Notebook
NOT PRINTING HELP PLEASE
Make sure that the ribbon is correctly loaded in the machine. Here is what to look for:
On the back side of the print block, the ribbon must pass between the two parts of the ribbon sensor. The upper sensor is located on the back of the print block itself, while the lower sensor is located on the black plastic arm that extends from the main printer wall.
May 16, 2008 | Toshiba TEC B-472 Thermal Label Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Zebra Z6M Plus Thermal Label Printer Logo
97 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
