Question about Dell E207WFP LCD Monitor
Dell Monitor E207WFP Picture Not Centering
Help!
Turned on my computer this morning like every morning and all of a sudden my entire desktop display is not center and skew towards the right. Tried the auto adjustment adjustment and re-positioning the horizontal towards the left to center on my monitor, but still no luck.
What am I missing?
  • 2 more comments
  • patriciasquo Jun 17, 2009
    Just tried my old monitor and it looks fine. I've already tried several times to reset to factory settings and checked the VGA cable, but no change. How do I reinstall the graphics driver?
    Thanks!
    Dell Monitor E207WFP as referenced above in title.
  • patriciasquo Jun 18, 2009
    How do I find this information?
  • patriciasquo Jun 19, 2009
    My centering problem is corrected now, but the screen looks like all the graphics and fonts are smudged towards the end of the sentence, right side of each picture or graphic, etc.. Is this also graphic card problem?. If so, computer is a Dell XPS 210 factory direct one. Hope this helps!
  • 285 Answers
Try another monitor on the PC, see if that helps.
If it does, the monitor is faulty. Try resetting it to fctory settings.
If it isn't, it's probably your graphics adapter, or something in between.
First check the vga cable, then reinstall the graphics driver.
I hope this helps,
Yannick.
Posted on Jun 17, 2009
  • 1 more comment
  • Yannick Verhoog Jun 17, 2009
    That depends on the type of graphics card. Could you please post your model here?
  • Yannick Verhoog Jun 18, 2009
    The model of your graphics card, not the monitor model.
  • Yannick Verhoog Jun 19, 2009
    That depends on what PC you have.
    If it is from a brand (i.e. it is a Dell or HP or something) you could just post the model they call it, and I can then find the other info on the internet.
    If it is assembled from individual parts, either by you or the store you bought it, all the parts should be listed on the receipt.
    I need to know the exact model of the graphics card. Its name will contain the words "Nvidia" or "ATi", so that's what you can recognise it from.
My dell E207WFP monitor only displays auto detect self test and before that was a lock.
Assuming your computer is functioning ok: then either your graphics card is not recognizing the monitor, the cord is not connected properly at both ends, or the monitor is defective and not displaying the signal. I would switch the monitor with another one, or try it on a different computer. If it works properly then you have narrowed it down to the graphics card. Remember, this is assuming your computer is OK. Try a different monitor on your computer, too.
Oct 11, 2017 | Dell Computers & Internet
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
I hit something on my keyboard and now my computer monitor turned the display from portrait to landscape. What keys do I hit on my keyboard to turn the screen back to normal?
If you are in Windows 7 right click on the desktop and select screen resolution. A window will pop up. You can change the orientation from there.
Apr 21, 2011 | Dell E207WFP LCD Monitor
Dell monitor will only duplicate laptop screen. I want to extend. This was working before and stopped after removing and reconnecting monitor
Right click on the desktop, go to properties, go to settings tab. There you will see your display adapters. Identify screens 1 and 2. Assign monitor 2 to extended desktop. This is where your issue can be solved. Play around with it and get to know it. You can change the monitor to right and left, etc.
Jan 11, 2011 | Dell E207WFP LCD Monitor
I have a Dell E207 WFP..How to I get a full screen picture?
You need to set your PC video resolution to the monitor native resolution which is 1680x1,050@60Hz
Mar 21, 2010 | Dell E207WFP LCD Monitor
My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Mar 22, 2009 | Dell E193FP 19" LCD Monitor
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Small crack in the LCD - should there be any picture at all?
Ted,It sound like the LCD was Dropped,Data going to it,Should show up,How about when you Press the Menu button does it display the Menu Let me know ttech
Jul 20, 2007 | Dell E207WFP LCD Monitor
Dell E207WFP LCD Monitor Logo
214 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
