Question about Kenmore HE2 Plus Front Load Washer
My He2 will do the final spin but only partial
My He2 will do the final spin but part way through it will stop as the control panal goes blank, no blinking likghts or codes and then it won't open as the door is still locked.
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My 90 Astro van won't stay running while in drive or reverse, any ideas
If you have a code reader, you should use it. When the oxygen sensor changes from open to closed loop, the issue can be related to bad grounds, bad oxygen sensor, bad MAF sensor.
Apr 30, 2017 | Cars & Trucks
Four minutes after a wash cycle starts, the machine stops, all selection lights blink, alternating with code FG28. What's wrong?
The F11 and f28 codes are from a communication break in the serial link from the CCU (Central Control Unit) to the MCU (Motor Control Unit)(from the brains to the washer motor controller). Stay with me here!
There are three blue wires that go to the MCU from the CCU. Most of the problems probably occur during the final spin when the machine spins fastest and longest to extract all of the water.
Hence, the most vibrations cause the connectors to shake until there is a break in communication!
Take the top of the machine off (three #20 torx screws on the top back) to gain access into the machine. The CCU is top center back and has the spaghetti of wire going to it. You will see white wires on the far right of the CCU. Then going left they turn to black. The black set (3 wires) left of the row of white wires if for the Door Lock/Unlock. It IS a problem for the F/DL error. It is not making a good connection. Next the blue wire on the LHS of the CCU, last set (back) there are three blue wires. These 3 go to the MCU and are the serial communication lines. Tighten all these wires to make sure they are making good connections. Make sure your machine is level with all the feet on the floor. You do have a 24 month warranty one the machine so call a tech if within that period. To insure that this may be the problem, take a ride and sit on it during the final spin ;-) If it works then you know it's probably the wiring, if it doesn't buck you off first.
getting f28 error code Kenmore Elite HE3 Washing Machine
Close the door. Select any key (except stop), using the same key; Press/Hold-4 seconds, Release-4 seconds, Press/Hold-4 seconds, Release-4 seconds, Press/Hold-4 seconds, all the led's will flash for 5 seconds. Any failure codes will display in estimate time remaining and the led's will flash. Press the same key to advance to the next failure code. If the console does nothing the same failure code was recorded multiple times. When there aren't any more failure codes all the lights on the console will turn on for five seconds then tell me what you got.
http://www.applianceblog.com/mainforums/threads/12233-Kenmore-HE2-Gives-me-error-code-f28-and-missing-ring
Jun 15, 2015 | Kenmore HE2 Plus Front Load Washer
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Kenmore HE2 washer will not automatically advance through all the cycles
I had this same /similar problem with my machine and found that the micro-computer board on the top rear near the cover of the machine are very prone to having bad electrical contacts on the board where the wire connectors go. The answer simply was to remove this board and add solder to each and every solder pad that goes to the connectors. The board is not bad (defective) just poor electrical connections.The repairman probably just wiggled the 1 with the issue and it worked for you for months as described! Perhaps you could get away with just disconnecting the electrical connectors and plugging them back in -it could buy you some more time before fixing it permanently with solder!
Good Luck!
Rich Lilja
Mar 05, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Codes SD and F1
im sorry to say but your main control board to the machine is now defunct aka broken you can find the ecb at marcone appliance online and they will mail you the part directly to your front door hope this helps sorry about the bad news
Jul 17, 2010 | Kenmore HE2 Plus Front Load Washer
My washer does not seem to be going through the rinse cycle.It doesnt drain all wash water out. When it FINALLY stops the letters Sd are lit............WHY
overdose of detergent during wash cycle try running the unit in a rinse spin here is also a tehnical sheet that u can get from this site as a pdf sd stands or suds lock http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
373 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
