Question about LG LRTP0931 Top Freezer Refrigerator
Fridge play up randomly
We have 2 250 to 339 litres LG fridges with digital control at the fridge department. Both of the controls have been replaced, one fridge even the bottom control box which located beside the compressor has be replaced. They work well for a period of time, then the fridge  warmed up one day. Is it because the faulty new parts ?What else we can do with them?
Please help me!
  • 878 Answers
SOURCE: Water tank inside fridge for water dispenser leaking
peah, I had a couple of these tanks leak. I think they had an issue with this. The last one I had they had a kit where the substitued coiled tubing with 2 john guest fittings to replace the tank. This solved the problem. The part number I have for the tank is 4838jj1003a, you can get it at for 17.95. I don't know if they will send you the tank or kit. You can inquire. back.
Posted on Apr 13, 2007
  • 1462 Answers
SOURCE: Ice, drips and soggy peas!
never buy a fridge with an ice box! the freezer compartment is not cold enough for long term storage and all of them build up ice. however, check door seals carefully as you may have an air leak past them. "4" is a reasonable setting and the stat controls both sections. also check that the compressor stops and starts regularly. if it is constantly running, you could have a compressor fault
Posted on Apr 27, 2007
  • 400 Answers
SOURCE: LG GR-292R freezer works/fridge does not.
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
SOURCE: LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Posted on Oct 18, 2009
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
Lg premium EZ digital. Digital display for fridge temp moves on its own can not control ice and water selections digital panel uncontrolable
Sounds like contamination inside the controller. Unfortunately this usually means replacing the controller.
Apr 20, 2012 | LG Refrigerators
No power & not running
Hi, you have to check few things, first of all check power at the outlet for 120 volts. If the light in the fridge works, the defrost timer, cold control and possibly the wiring are the most common things that can make a fridge sit there and be dead, not working.
The defrost timer might be stuck in defrost, turn the timer screw to advance the timer and if the fridge comes back on, replace the defrost timer. You can join the wires together to by-pass the cold control for a test, if the fridge comes on, replace the cold control...
Take care
May 02, 2010 | LG LSC26905TT Side by Side Refrigerator
My LG 22850 fridge light stays on all the time
Contacted LG Canada they were great just gave them the serial number of my fridge and are coming out to replace the parts no charge (the fridge is
way outside warranty)
Dec 31, 2009 | LG Refrigerators
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
Lg fridge
heating element seems bad,,sometimes a easy fix
Jan 20, 2008 | Refrigerators
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
LG LRTP0931 Top Freezer Refrigerator Logo
54 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
