Question about Canon MF3110 All-In-One Laser Printer
Troubleshooting my printer cannot print and scan as it is accepting paper
Hi
how can chek counter in mf 3110 ????
masifjohn@yahoo.com
Posted on Feb 15, 2008
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Will the HP 2700 scan without an ink cartridge loaded? I am getting an error message about a problem with the black ink cartridge and it is overriding everything else. All I want to do is scan.
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Photosmart 2710 All-In-One InkJet...
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
Printer was working fine, until it's outflow was accidentally obstructed. Obstruction removed, but now error light comes on immediately, and printer won't print. There is nothing blocking the paper path,...
Try this troubleshooting prodedure. Turn on/off, unplug, plug in2_bing.gif, should reset configs.
Take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
Go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
Go to web site of printer model and check site for trouble shooting if this does not work above. Hope this helps and good luck
May 31, 2010 | Brother HL-2170W Laser Printer
The feeder on the top of my d1150 will not accept paper it keeps jamming, i have been scanning alot of documents the last two days and now it will not scan anything, it keeps jamming
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Canon imageCLASS D1150 All-In-One Laser...
How do i scan a paper? i press scan and it won't accept the paper im putting into it
The scan button on the printer is to scan to PC and then save it to computer and then print it.
Steps for scanning from Computer.
Windows Vista:
1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan
Windows XP.
=== Scanning with Paint: ===
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Sep 30, 2009 | HP Officejet 4110 All-In-One InkJet...
Engine LSU error, printer will not print. Accepts paper half way then it stops.
lsu stands for laser scanning unit. it tansfers the image onto the transfer drum, common problems are horizontal sync, i would suggest a replacement lsu
Sep 24, 2009 | Samsung ML 2151N Laser Printer
Canon MF3110 All-In-One Laser Printer Logo
73 people viewed this question
old marine
old marine
