Question about HP 12c Calculator
How do I reset to get rid of a '','' from my hpc calculator
  1. Turn off the calculator.
  2. Hold down the decimal point.
  3. Continue to hold the decimal point key, while turning on the calculator.
The comma should change back to a decimal point.
Posted on Jun 23, 2009
Can't get rid of deg in sharp calculator
It simply indicates that the calculator is set to degrees. The calculator has three angular modes (degrees, radians, and grads). No matter which mode you set, the appropriate indicator will light up.
Dec 06, 2012 | Sharp Scientific Calculator El-509s,...
I get a STAT Error message when I push the DATA and STATVAR keys.
There's a manual free to download at the manufacturer's website that has more information and tips for getting the most out of your calculator.
Aug 31, 2012 | Texas Instruments TI-30 XIIS Calculator
My screen says
If pressing the CLEAR key doesn't get rid of it, reset the calculator.Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Turn the calculator on. You may have to adjust the contrast to make the screen visible.
Apr 18, 2012 | Texas Instruments TI-84 Plus Silver...
How do I get rid of the border on the screen of the TI 84?
First try the screen formatting (2nd, zoom) and reset the axis (select the option turn them off and then turn them back on again)
If that doesn't work try clearing out the memory (2nd, "+", "7", "1", "2")
Unfortunately this will erase everything on the calculator
May 30, 2011 | Texas Instruments TI-84 Plus Calculator
The calculator appears to be frozen; none of the buttons respond; the display only shows "Ans" with a little 2 above and to the right of it, making it look like Ans is squared and then a blinking cursor
If pressing CLEAR doesn't get rid of it, try resetting the calculator. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
How do i get rid of the "p" on my sharp caculator. I have a EL-520W
On the back of the calculator, there is a little "reset" hole. Use a pen and press it into that hole for a few seconds, then release. You should now be able to turn on your calculator as if it was brand new from factory without the "p".
May 19, 2010 | Sharp EL-520WBBK Calculator
I have the letters DEG with an up arrow in the right top of calculator screen that I cannot get rid of. It will not allow me to compute square roots or anything. How do I get rid of these...
Sorry, I do not know what problem your calculator has, but it certainly is not related to the presence of the DEG indicator in the top (user inaccessible) part of the screen. This is an indicator (or a reminder) that the angle unit was set to Degrees. If you change the angle unit to RADian, the DEG indicator will be replaced by another that displays RAD. Whenever the calculator is turned back on again, the angle unit is reset to degrees. What can one do? Better accept it, tolerate it, or ignore it.
So the gist of the story is that you cannot get rid of the indicators.
This answer is certainly not what you wanted to hear, but I am only the messenger, albeit one who volunteered to help a fellow human.
Greetings.
Nov 01, 2009 | Texas Instruments TI-30XA Calculator
Very thing is up and i need it to be reset
To reset the calculator, you press [SHIFT][9] (CLR) then select 1:Setup, 2:Memory, and 3:All. I guess, if you want to get rid of all the settings you modified you have to press [3:All][=].
Hope it helps.
May 12, 2009 | Casio fx-300ES Calculator
Sharp EL531WH Calculator
I had the same problem... all you have to do is reset the calculator:
Type:
2ndF
ALPHA
It'll give you a choice Mem (0) or Reset (1)... press 1
Then it'll say Reset? (0)... press 0
And your calculator should be as good as new!
Sep 06, 2007 | Sharp EL-531VB Calculator
HP 12c Calculator Logo
230 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
