Question about HP 12c Calculator
Dropped my HP 12C into the sink (full of clean water)
I immediately (3 seconds) retrieved the calculator-dried it out the best I could- drops came out the front- took out the batteries and warmed the unit with a hair drier.
I have had this little guy for over 12 years and I hate to say good bye.
Any advice ? Bill
  • 483 Answers
Yes, take it apart, and wash the circuit board.
Hard part is taking it apart without breaking the little tabs that snap the case together. It may have a couple hidden screws somewhere like in the batt compartment or under a label or under the rubber feet. Then carefully pry the case joint apart to get the snaps to let loose. Then the circuit board easily comes out - be careful if all the keys are loose not to disturb them. Also be careful of the display that may be loosely mounted. Once you get the board out, you can wash it with soap and water - whatever, just rinse it when clean with something like alcohol so no residues are left. Also be careful to not rub off any off the black key contact spots where the keys touch it. Put it back together loosely and see if it works.
Hope Ya Fixit !!
Fame !
Posted on Jun 17, 2009
Dropped HP12c won't turn on
Batteries may be dislodged in compartment.
Apr 17, 2014 | HP 12c Calculator
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
I have a problem I am trying to raise 1.020408 to the 2.43 power. How do I accomplish this? The answer should be 1.050388. I am using an HP 12c
More like 1.050317175 .
Press 1 . 0 2 0 4 0 8 ENTER 2 . 4 3 y^x
"y^x" is the first key in the second row, below "n" and above "R/S"
Jul 19, 2011 | HP 12c Calculator
If log 1000 = 3, how do I do this with my hp 12c calculator
The 12C does not have the common logarithm function built-in, but you can calculate it using the natural logarithm function (the blue g shift of the %T key, 2nd row, 3rd key).
The common logarithm of x is the natural logarithm of x divided by the natural logarithm of 10, or
log x = ln x / ln 10
Press 1 0 0 0 g [LN] 1 0 g [LN] /
and you'll get the result 3.
Jun 06, 2011 | HP 12c Calculator
How can i tell the difference b/w hp12c and hp12p. i bought a hp12p from ebay(it's a stupid decision, I know!) and when i solving for IRR, i felt its running quite slow. I think the guy sold me the hp12P...
I couldn't find any reference to a HP calculator model 12p.
There is a HP 12c financial calculator and a 12c Platinum financial calculator.
Check both models (for images, specifications, functions, user guides, etc.) :
HP 12c Financial Calculator
HP 12c Platinum Financial Calculator
Aug 06, 2009 | HP 12c Calculator
Dropped my phone in sink of water
You may have caused a short in the device. Basically once your cellphone is exposed to water, the best solution would be to IMMEDIATELY remove the battery, and place the device in a bowl of rice. The rice serves to absorb the moisture, and within a day, should restore your phone :D.
It doesn't hurt to take it apart and dry it by hand though, but by trying to use a non-dry phone you may have to get a new one.
May 21, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Wont turn on after being dropped in toilet.
There might have been some water in the circuits. try taking it to the game store for repair
May 16, 2009 | Sony PSP-3000 Silver Console
Dropped camcorder in sink full of water
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 20, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
Sep 04, 2008 | HP 12c Calculator
Calculator dead
Can you plug it directly into a adapter, and will it work?
Feb 26, 2008 | HP 12c Calculator
HP 12c Calculator Logo
185 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
