SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
SOURCE: Sharp MX-M450N getting F2-00 error
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
SOURCE: I have a sharp mx m450n photocopier which almost
A H5-01 means that you have had more then five jams in the fuser and the copier locks up to warn you that there is a problem with the fuser > it is a safty feature so that no major damage will be done. It needs to be reset in service mode.
