Question about HP LaserJet Q2612A Printer
Refilled my #21 cartridge, poor or quality or nothing is printed.
I refilled my #21 cartridge (myself) and after 5 good pages, the print became faint, then worse, now barely visible.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You need a refill like this way in order to remove the air bubbles
http://www.youtube.com/watch?v=dhDaKSzou50
Posted on Oct 29, 2010
  • 159 Answers
You have an air bubble between your print head and ink supply. This is something that commonly happens when you hand fill these cartridges. These cartridges need to be filled under vacuum to prevent this from happening. I recommend refills from Cartridge World because they have good prices with a 100% satisfaction guarantee.
Posted on Feb 06, 2010
Poor print quality - dots on side of copies
Using refilled cartridges? avoid refilled one, remove cartridge, used blower blow out toner fallen in side,take 25 pages of blank pages print outs, then go to menu>configure device>fuser modes select clean page wait to clean it self, do this process twice or thrice till fell print quality good.. if no result replace teflon sleeve(replacing the teflon sleeve only professional can do)
Feb 01, 2012 | HP LaserJet P4015N Printer
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
I refilled my cartridge for x2650, its full, but doesn't print I refilled my cartridge with ink myself that i bought from Argos, now it is full of ink, but still shows the message that i must replace...
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
Aug 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Dec 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet Q2612A Printer Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
