Printer will not print. when I go to see what the screen says it gives me the 900 Rip code
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
SOURCE: My Dell M5200 printer says 900 Service and RIP
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
