Question about Refrigerators
The freezer coil in the lower freezer section freezes up with ice. I have the upper section at 5C and the freezer 18C. We first notice that there is water under the fruit drawers and the fridge seems to be running a lot. This tells me that it is time to take the inside of the freezer apart and apply heat to the coil until it is free of ice. The coil is so full of ice that the freezer has to be heated to remove the outer panels as the ice is holding the panels.
  • 483 Answers
Unplugged it and defrosted the coil with a blower and it starts working fine ...
It it happens again perhaps defrost sensor, timer, or perhaps the heater coil being a problem. the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Thanks
Fame !
Posted on Jun 17, 2009
I have a Hotpoint iced diamon fridge freezer, given to me second hand by a friend, no manual. Can anyone tell me what the two or three lights at the top mean with a picture of one droplet to the right of...
the drip ledge is for the drain hole in the middle which should be cleaned periodically.it is fitted for the condensation from the fridge to drain away.the "droplets"are ice crystals and one droplet is normal running,two us for fast freeze(when you have just filled/started from warm)the lights are "on and running"......fast freeze.......and overheat warning.as far as level 3 is concerned,get a frezzer thermometer and run the freezer at -18C and the fridge at +3C to 5C.,as it will change depending on the weather/kitchen temperature.(summer and winter).
Nov 10, 2010 | Refrigerators
Recently got called out to an aeg electrolux s range.found evap drain pan in freezer to be iced up.the reported fault was fridge section too warm.found evap fan blade caught in ice, ducted air not getting...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Feb 26, 2010 | Refrigerators
22 cf kenmore side by side not very cold. Large ice block formed behind backplate on upper coils. thick frost on lower coils and on inside back of freezer section. Still making ice and fan blowing,...
also perhaps the defrost timer is bad, not allowing the defrost heater to come on and melt the ice as it should? Or the defrost heater itself could be bad -
Oct 07, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
We inherited a Roper refrigerator with the purchase of our house. There is freezing cold water dripping into the refrigerator section from the freezer section. Often times the water will freeze within the...
Oct 02, 2009 | Refrigerators
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Sep 21, 2009 | Kenmore Refrigerators
There is icing up in drip pan causing fan to stop working due to ice build up
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
If the coils are also icing up you have an auto defrost problem.
Jul 01, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge fine, freezer not freezing
Weird scenario... the first thing I would do it to remove the interior back panel of the lower freezer section after the unit has been running for hours and check the coils to see the frost pattern on them. Should be even white frost all over the coils with no solid frozen coil (block-O-ice thing). Check the fan is running above the coils, etc. when. If everything is OK then you may have a control board problem. Let us know what you find in the freezer coil investigation and we can go from there.
Jan 15, 2007 | Samsung RB2155SH Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
