Question about Sharp AR-M350N Black and White Copier
Light Copies I have a Sharp AR M350N+ in which I just changed the toner cartridge. I have checked the exposure settings and they are normal, but my copies are coming out light. Could my problem be the developer? I cancelled the maintenance agreement on this machine and before I call for maintenance, i thought I would try to find out if it could be just that i need a new developer cartridge. Faxes that come through the machine are normal. Thank you.
  • jford568 Jun 18, 2009
    Thank you. I may try that.
If faxes come in ok then the developer is ok for now, and the problem is primarily 'optical'. The laser optics could be dirty and that is not something to be cleaned by an end user, however, you can try cleaning the scanner optics by turning off the machine, remove the screws around the scanner glass, remove the glass, clean and set aside, then slide the scanner to the side and clean the mirrors, and bulb, with a very soft cloth, and mild glass cleaner, replace and see if the quality has improved (It should be at least somewhat to quite a bit better)
Please let me know
Posted on Jun 18, 2009
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
My copies are not very dark
Is the problem only with copies? Does the machine also print light?
If is it copy only, remove the glass and clean the lamp and mirrors in the scanner.
If it is both copy and print, then you should clean the laser shield glass and replace the developer.
Jul 28, 2010 | Sharp AR-M455N Copier
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Copies get stucked in sharp ar-m350n fuser
check the fuser roller gears ,the impression between the two roller and the paper seperators one of these is not in good shape.
Feb 21, 2010 | Sharp AR-M350N Copier
My sharp copier ar 5316 has printed 0nly les than 1600 pages and now showing toner cartridge low, even les than 10%
please check the devoloper , if the quantity is lessthan the specified the same quantity will be filled with toner.
Oct 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M350N Black and White Copier Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
