Bought a behringer xenyx 1202 and I want to connect to a delta 1010LT to do 8 track simultaneous recording. Is this possible?
  • 26 Answers
SOURCE: using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Posted on Apr 09, 2009
SOURCE: SE2200a, No input signal
If my comment helped you find this problem, could you respond to the fixya questionnaire accordingly?
thanks...
Charlie
Posted on Apr 22, 2009
  • 1138 Answers
SOURCE: Do I need to connect the Xenyx 1202 to an amp?
If you are the only person listening, you can use headphones with the headphone jack. Otherwise you will have to use some sort of amplification and speakers,e.g. P.A., stereo etc. I'm using a Xenyx 1222 FX and am quite happy with it.
Posted on Apr 23, 2009
technical114
  • 1851 Answers
SOURCE: Set up audio mixer with PC
You must connect:
the main out of the 1202fx, or the ctrl room out of the 1202fx at your power amplifier's input (if there is one)
the line in 11/12 of the 1202fx at your pc's audio card line out. (for playing back)
the cd/tape out of the 1202fx at your pc's audio card line out. (for recording)
in case of a cd, connect it's line out at line in 5/6 (or 7/8, or 9/10) of 1202fx's
some mic at the mic 1 (or 2 or 3 or 4) of 1202fx.
That's the way you're going to have control for:
the mic level from channel 1 (etc).
cd level from channel 5/6 (etc).
pc playback from channel 11/12.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
About freeware softwares for audio recording and editing I can suggest you:
Audacity (homepage)
Wavepad sound editor (homepage)
In case of a problem or clarification about the connection or the cables, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
How dso I connect a seperate mixer to a Behringer B215D powered speaker
Use the two balanced outputs, intot he inputs on the back of the speaker, 1/4 inch jack should fit.
Alternativly you can do the same via xlr, for a balanced connection.
Jul 28, 2014 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
POWER SUPPLY PSU6-UL does not fit xenyx 1202 fx
That is what is connected to mine and it works great.
Mar 21, 2014 | Behringer 1202 Small Format Mixers
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
I have a Behringer xenyx 1202 fx. I get static when I turn up the main fx to main control. I've had the unit for a year working fine until now.
Sounds very much like the control knob is dirty, needs a good cleaning!
Sometimes just giving the knob a good exercising (turn it up and down quickly a few times) can help it.
Some cleaners can leave behind a residue and make it worse, so ask at an amp repair place what product is best to use.
Hope this helps!
Jul 13, 2011 | Behringer XENyX 1202 FX Bundle
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a behringer Xenyx 1622 mixer and am using cubase when i plug it in the it says its ready to go but, something happens and theres no volume..and i cant set it up in cubase?...any suggestions..
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Apr 27, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
Monitoring problems
i have a prolem in the play back device
Apr 20, 2008 | M-Audio Delta 1010LT Sound Sound Card
56 people viewed this question
 Grubhead
Grubhead
