Question about Mitsubishi WS-55859 55" Rear Projection Television
Timer light blinks rapidly, set will not turn on...
We had a tornado last week, I was watching the weather when the power failed. When it was restored 23 hours later, everything else in the house worked but the TV will not turn on. Tried resetting and when release the button, the light resumes blinking. Repairman I called said probably the DM module for $400 which will probably mean replacing the set. When I listed it on Freecycle, one reply said I could replace a fuse for $5 and solve the problem. Any ideas appreciated.
    Problem Solver:
  • 13 Answers
Well you could replace caps in the dm module they are 1000microfarads @16 volts there are 7 of them 99% of the time that works if not you have a problem with the e2p module which is also located in the dm this will definitley fix yiur problem
Posted on Jun 17, 2009
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Timer light is blinking and won't come on
Thats a very common problem with that model which is the V26 chassis. You can get the V26 Chassis DLP DM ? Power repair kit from www.tvrepairworld.com which has the replacement caps known to fail on the DM and Power boards. The kit also has the CD with step by step repair instructions.
Aug 06, 2012 | Mitsubishi WD-62725 62" Rear Projection...
My Midland WR100 weather radio is set for any S.A.M.E. code. I live in Oklahoma. We have tornado warnings and severe thunderstorm warnings, and my radio has not sounded. If i press the weather/snooze...
I have been used this Midland weather radio with S.A.M.E alert for last 2 years. My device works perfectly. My radio has sounded whether any tornado warnings and severe thunderstorm warnings. After reading your post you have to face some problems with your device, that during tornado warnings and severe thunderstorm warnings your radio not sounded. If you follow some steps then your issue will be resolved. Carefully review the manual. Or, it is possible that the NWS did not issue a warning for the storm. Warnings are issued for thunderstorms. If a storm is not expected to produce severe weather, a warning with an alert is not issued.
Best Weather Radio Reviews Be Prepared For Natural Emergency
Dec 13, 2017 | Midland WR-100 Weather/RDS Radio
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Green blinking light under timer
I can almost guarantee that the circuit board(s) have bad capacitors on them. I repaired one last week that had 20 bad capacitors on 4 boards.
Fixed one the week before with 15 bad caps on two boards.
A repair shop may be able to replace the boards, but it may be expensive.
- I hope my diagnosis is wrong-
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-55859 55" Rear Projection Television Logo
275 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
