Question about Philips 25PS40S 25" TV
My philips 25ts56 c221 will not come one.
My philips 25ts56 c221 will not turn on i checked the fuse in it and the fuse is fine does any one know what else it could be thats causing it not to come on.
    Problem Solver:
  • 9 Answers
Re: my philips 25ts56 c221 will not come one.
You and many others i have a philips 28inch and it seems that a common problem is when they try to turn on it has a surge that then sends it back to standby if this the problem then you will expert help cos the backs got to come off and some componets changed but you dont say if you are ok to do this yourself?  Maybe the fuse inside the set or maybe there is a wire come loose in the plug or in the set. If you are not up to working on the internals then take to tv repair shop!!
Posted on Nov 01, 2007
0 characters
3 Points
I need reset smartlock code for C221 magnavox ms2730.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Unlock procedure to many popular brand TVs are given by one among the posts.
Oct 12, 2014 | Standard (CRT) Televisions
Toshiba 27D46 will not come on?
It may be a fuse. But something else may have blown the fuse. I would check the circuity of the power supply.
Oct 27, 2012 | Toshiba Standard (CRT) Televisions
Sony WEGA 36" will not
Sony sometimes use a balance power supply, similar design to the Philips design from1978 but updated. A realy efficient and nice design but when it dies it takes out quite a lot.
There is a mains fuse that feeds the bridge rectifier which in turn feeds the power supply. If that is the fuse you are refering to, seek professional help. The circuit is finely ballanced and must be correct otherwise it will go bang again. If this is not the fuse then look for a short circuit on/off switch or filter capacitor network on the A/C side, before it gets to the main power supply.
Hope this helps.
Dec 31, 2010 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Philips TV 27PT6441/37 won't turn on - I know I need a 4 amp slow blow fuse. Will it be obvious where the fuse is located once I have the back cover off or will I need to find a schematic?
Yes it will be obvious and you don't need a schematic to find it. What you actually may need is an ohmmeter to find exactly what fuse is blown in case there are more than one fuse present. You can also find this symbol on the board that indicates the fuse. Sometimes this symbol is drawn inside a box.
Nov 06, 2009 | Philips 27PT6441 27" TV
Television won't turn on
Sounds like a power supply problem, you'll have to take it to a repair shop to fix that unless you know electronics. Good luck.
Nov 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Television not turning on
If you want to check fuses find a Multimeter that has a continuity tester They shouldn't cost to much maybe 20.00.
Oct 06, 2008 | Standard (CRT) Televisions
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips 25PS40S 25" TV Logo
122 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
