Question about Bernina Activa 140
Bernina Patchwork 140 handwheel is getting stiff to turn
Is that normal? Does it need oiling?
  • 208 Answers
A stiff handwheel can be a simple as a thread stuck in the raceway or as severe as a failed uppershaft bushing.
Using your instruction manual, perform the basic maintenance and see if that helps. If not, take it to a repair person for evaluation.
Posted on Jun 17, 2009
I have sewing machine "juki ddl 8500". My oil sight doesn't show the oil, it's dry. Is this normal?
Not normal .... you should see splashing in the sight window on top of the machine ... if lubrication is adequate.
To be sure ... lift the machine off the bottom basin and check to see if the oil level is between the "high" and "low" marks. If it is below the "low" mark then the appropriate oil needs to be added.
And ... if all the current oil looks bad (debris in it ... more brownish color) then all the oil should be replaced
Mar 15, 2018 | Sewing Machines
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
A squeaking noise just started. Does this machine need oiling?
Yes On Any Sewing Machine You Should oil It.! When it come's brand new in the box it normally comes with a little bottle of oil it is a must to oil the treader Etc.
Jul 31, 2017 | Sewing Machines
I need to put oil into my Juki ddl-8700 Industrial machine. I am terrified of doing something wrong and starting a fire. Instructions mention "oil splash". Please help me get started. Thank you
I just looked over an on-line version of owners manual. You have to put oil to high mark. Some small amount of oil splash seems normal. The machine is going to cause some vibration to the oil tank. As long as you have all adjustment right there should not be problems. Keep a small towel handy to wipe off any oil that comes out. If you don't have enough oil for the needle and machine the motor will lock up (seize) Be safe by always cutting power to machine if you are going to do any kind of service to it. Just as with a child, don't leave it running if you will be away from it for more than a couple of minutes.
Dec 06, 2016 | Juki Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
How and where do I apply oil to my machine? It normally is in the instruction manual, but I cannot locate mine and the PDF available online does not contain that information. Thanks in advance!
If it is a computerized machine, there are usually only a a couple of spots that need oiling--generally the hook area.
If a mechanical machine, there are multiple places that should be oiled:
It was working now it seems to be frozen the needle part wont move
Apr 03, 2016 | Sewing Machines
How do I unjam the gears in my bernina 830?
If this is a Bernina 830 Record and the handwheel is stiff or does not turn, about 98% of the time the machine needs oil. Another problem could be a cracked or broken gear (one or both of the white plastic gears in the top but unless you are very handy, your Bernina tech should probably take care of this repair.)
Mechanical machines need to be oiled regularly just like your car. If the machine sets in storage for a while or is used often but not oiled or cleaned regularly, the oil that exists in the machine will eventually thicken and acts like glue. (Sometimes you can see a dirty-looking dark gold or brownish goop which is usually old oil.) Then your machine is frozen.
There are quite a few oil holes (both in the top and bottom of a Bernina mechanical) that require periodic oiling (see your machine Manual). If the handwheel is frozen, buy a bottle of liquid Tri-Flow Synthentic Oil (from the hardware store) and put one or two drops in all the spots shown in the manual. (DO NOT oil the two white plastic gears or the metal CAMs!!! NEVER use 3-in-1 oil, cooking oil, WD-40, or a generic sewing machine oil from the fabric store. And do not put more than one or two drops of oil at a time as over-oiling will also damage your machine.)
Then, using your hand-held hair dryer, direct hot air into the internal part of the machine (top and bottom). The metal may become very warm to the touch. Then try to gently move the handwheel. Repeat. Even letting it set overnight may help.
Once the handwheel loosens, slowly hand-rotate the handwheel and watch where metal parts move against each other, put a drop of oil in each of those. Be sure to move the selector knobs and oil where metal moves against metal to keep those working.
To maintain your machine, a good recommendation is to oil every time the bobbin thread is changed, every 8 hours of constant sewing, or every six months if the machine is not in use. Use a good quality oil, ie Bernina oil for "mechanical" machines. When oiling, also be sure to brush out the dust and lint (especially around the feed dogs and bobbin works).
If the oil in your tube looks dark colored, throw it out and get some new. I've run across some old sewing machine oil in the can that looked like dark honey and stunk to high heaven. Get rid of it!
Treat your machine well and it will serve you well for many years.
Jan 04, 2015 | Bernina Sewing Machines
My sewing machine started to sew slow and seem like it is working hard. Won't sew normal. Hasn't been that long since it was last serviced/oiled. Any suggestions?
Slow is due to friction in the shuttle drive and key moving bars and joint. Apply few drops of petrol/kerosene and run for few minutes. Then apply normal lubricating oils meant for machines.
Dec 15, 2014 | Sewing Machines
Sewing Machines Logo
405 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
