I recently recieved 2 camera's: a x300 and a x700. It took me a while to find the right battery, but both the camera's won't 'start up'. They are in excellent shape: nice bag with with extra lenses and flashes and stuff. So I think the previous owner was pretty careful. So, what could be the problem?
These use two of the L44 common button battery. The + sides of the battery (flat) goes towards the body ... the bump goes towards the battery holder. Check the contacts on the body and where the threads (-) contact the body. Not voltage, no work. Assuming you have 4 different batteries, can you check the batteries ? One bad one of two will not allow voltage. I have bought new button batteries that were dead right from the package. Strange two cameras are dead. They have electronic shutters. The LED should light up in the viewfinder when the shutter is slightly pressed.
SOURCE: Canon A95 gone dead
I ain't so lucky I'm in the UK too!!!! Generally speaking the cost pf packing, shipping repair, at any level is well on the way to the price of the next more recent higher specification device. Judging by the way the Megapixels go up by the week seemingly, settling for a replacement camera is usually the best option. I had a cheap[old] Fuji come my way because it had gone blurred and blue - sure sign of a CCD failure as this was at some time the subject of a recall for the problem I checked out Fuji Their response was to say no longer repaired but has a 1/3 off a new camera when I quoted a reference number. That seems to be the way to go.
SOURCE: lense adapter and extra lenses for fuji finepix E900
There are several of what you are looking for on eBay. They are slip on to fit the E900
SOURCE: minolta digital camera,s
Simple answer...Take your best working lens to a camera store,and ask to test a sony a100 digital camera. ALL Minolta Maxuum auto focus lenses work with the a100. This includes Konica/minolta type also. If you don't have an auto focus lens, it still might work-but you would loose some features, by swaping camera bodies. In the least it would cost you nothing to find out what camera they would work on, and save you enough money to partly pay for the new camera body you want anyway. Shoot a few stills with your lens on the different bodies-after all your not waisting film-until you find one that is good for you. The camera shop might even have an adapter ring for your lens to the camera body of your choice.
SOURCE: Manual Canon 50mm FD lense will not focus!?
In that case the linkage between the movable parts of the lens group and the focussing ring has failed.
What follows applies to most lenses; I have a Canon 50mm FD to hand but as it works perfectly I've not needed to dismantle it so far but have repaired many others.
When you turn the focus ring there are usually two pegs which engage into helical slots cut into the focussing ring, these are hidden within the lens and you won't see them unless the lens is dismantled. The pegs are usually rounded to make the passage along the helical slot even smoother and each one is fixed to the inner lens barrel by a screw. On older lenses, the grease inside can dry out a bit, especially if the lens remains unused, when this happens the pegs may either shear off or simply become unscrewed and drop off. The gummy grease may hold them so you won't always hear a rattling part inside.
To fix it, you carefully dismantle the lens to the minimum extent you can get away with. You'll need good light, patience and a set of good quality crosshead precision screwdrivers. Normally you start with the screws on the mounting flange and watch out for small springs and detent balls which tend to escape to freedom never to be seen again. Some of the screws are usually hidden beneath the rubber grip on the focussing ring, and you remove this to check by carefully lifting an edge and then rolling it back over itself. It may need re-gluing afterwards. Clean out dried grease as you go and apply a small amount of thick grease to replace it on reassembly: less is far better than too much! Some of the screws may need thread lock applied to them when they go back in, but you're better off leaving this as your first time lens repair usually has to come apart again due to an error in reassembly.
Be prepared to ruin this lens as it's your first lens repair. The good news is that auction websites have plenty of other cheaply and in full working order, just make sure to ask if the iris (aperture) works smoothly and snappily and that the lens does not have the dreaded lens fungus on the glass elements (a patchy white haze). You can also usually get these lenses for free on Yahoo FreeCycle and a camera body and other goodies normally come as part of the offer. FreeCycle is how I've collected various Nikons, Canons and Pentax SLRs and lenses over the last year to add to my existing Olympus gear.
I hope that I've helped you, if so please return the favour by rating my answer.
