Question about Lexmark T644 Laser Printer
Print job is totally black
Whether printing a test page or any other document, on a T644, the page comes out black. Checked the toner and there is toner residue on the roller. There is also a clicking/grinding sound which is coming from the printer as soon as it attempts to print. Changed toner cartridge with the same result. This printer is new, as well as, both toner cartridges. What do you think?
    Problem Solver:
  • 11 Answers
I know you've tried some of the below suggtions but I put the whole list there for everyone else. If this printer is less than a year old call them. Their tech support has changed a lot! They try to take care of you.
Possible causes:
· Check/Replace the toner cartridge
· Check the charge roll assembly (see Note below)
· Check the Toner Darkness, Brightness, and Contrast settings
· Try cleaning the inside of the printer
· Bright light/sunlight entering the printer (on right side of printer)
· Printing on media other than plain paper (make sure you're using laser paper- it makes a difference!)
· Using a refilled cartridge. Lexmark will emphatically tell you they are not supported.
NOTE: Checking the charge roller:
1 Power off the printer and remove the toner cartridge.
2 Look into the upper area of the printer where the cartridge was sitting. Located near the top of the printer you will see a couple of gray rollers. This is the charge roller assembly. See the area highlighted in the image below.
NOTE: If you cannot see the rollers, close the upper lid slightly and the rollers should lower into view.
For larger version of this image, click here.
3 Make sure the roller assembly is seated correctly into the holders on the left and right-hand sides. If not, try to reseat the assembly into the holder arm.
IMPORTANT! If the charge roller assembly is not present, it needs to be installed. Look around the inside of the printer and near the printer for the roller assembly. If the charge roller assembly is missing, you will need to order a replacement set in order to get the printer operational again. See the 'Additional Assistance' section at the end of this document for more information.
4 If the rollers are present and installed correctly, check their condition. If the roller surface appears dirty, take a clean dry cloth and carefully clean off any dust or toner. Do your best to ensure all of the roller surface is clean. NOTE: If any part of the rollers is damaged, the charge roll assembly will need to be replaced.
CAUTION! Try not to touch the rollers with your bare hands. The surface is susceptible to contamination and a permanent mark could remain on the rollers.
5 If you were able to reseat the charge roller assembly or managed to clean the rollers, power on the printer and try printing again. Print 10 to 20 pages to give the pages a chance to clear up. If the pages do not begin to clear, the printer will likely require service to correct the issue.
For more information on arranging repair service, please contact Lexmark Technical Support or an authorized service center. See the 'Additional Assistance' section at the end of this document for details.
Posted on Jun 17, 2009
Hp Laserjet P2055d-Page Counts error
are you looking at the pages printed on the toner cart. print out the supplies page.
Jul 28, 2017 | HP Office Equipment & Supplies
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Pages printing very dark
check your printer scanner. and replace it
May 21, 2009 | Brother MFC-9440CN Laser Printer
LEXMARK T644
Make sure that the toner is not leaking and check your connections from the HVPS. If they look good I would replace the printhead.
Roger
Sep 10, 2008 | Lexmark T644 Laser Printer
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Lexmark T644 Laser Printer Logo
438 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
