Question about Microsoft Xbox 360 Console
LABELS HI. I'M HAVING TROUBLE WITH JUST SINGLE LABELS-ie 10 DIFFERENT WORDS- NOT REPEATS. HOW DO I DO IT SINGLELY? THANK YOU.
I don't understand your question. What are the "labels" and how are they associated with your Xbox360? Is it possible that you've posted under the incorrect device category?
Posted on Dec 19, 2007
Is it possible to connect two jacks simulteanously to a speaker like S115 or SW118 coming from 2 different channels of a power amplifier like P5000S' please advise thanks
the s115 and p5000s are power matched for a single channel.
IE - the s115 is rated at 500W and the p5000s is 500W PER CHANNEL.
If you're trying to drive a left/right signal into a single speaker, you need to mix the left right signals together at the input side, and put the mix into a single channel of the amp, and then into the speaker from that one channel.
The other option is to have 2 s115's - one on each channel.
Mar 25, 2011 | Audio Players & Recorders
I am trying to print labels and the printer command says manual feed insert paper. What do I have to do?
1. Pull up a blank Microsoft Word Document.
2. Select "Tools" under the toolbar feature. Slide the cursor down to Letters and Mailing. Slide it to the Right and down. Select "Envelopes/Labels."
3. A box will open up. Make sure that the "labels" tab at the top is selected. The default is "envelope", so you must click on the "labels" tab.
4. Below that, you will see a "print" box. If you want a full page of labels (excellent for Christmas lists, etc.), make sure the "Full Page of Same Label" radio button is selected. If you only want to do one label, make sure the "Single Label" radio button is selected.
5. Off to the right side, you will see the word "Option." Press on that. Locate your label. Whatever labels you are using should have their classification number listed on the bottom left corner of the outside of the box. They tend to be 4 digits (ie. 5162 is the number for Avery White Mailing Labels.)
6. Once you have located your number on the box, find the corresponding number under the "Options Tab." Highlight it. Press Okay.
7. You will see "New Document" in the upper right hand corner. Press that.
Presto! You can now fill in an entire box of labels and send out very classy looking envelopes!
Feb 08, 2011 | Brother Office Equipment & Supplies
I have a Seiko Instuments Smart Label Printer 220. I have upgraded my computer to Windows 7 and I am runnng MS Office 10. Since upgrading I cannot get my smart label printer to work. I can get it to...
this is a problem that only the Manufacturer can solve for you . old devices do not like new operating systems or the other way around .possibly your only option is a new printer
Sep 21, 2017 | Seiko Instruments Smart Label 410 Printer
Hello, There was a problem in Sony W100 camera, ie
The easiest and best way to download pics is to use a separate card reader such as the one in this picture. 901953e.jpg
Aug 13, 2010 | Sony Cameras
Is there a way to get a single track to repeat?
Hi darasprio,
To make a single track repeat, go to Settings, Play Mode and select "Repeat". You can do this in the middle of a song, or when nothing is running, but either way the effects take place immediately, and the track you next play will keep on repeating unless you use he arrow keys to move on to the next one.
Note that the names of the menus given here might differ from that on your player.
Oct 29, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
Predictive text problems with my samsung u900
when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
rate me please thanks
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
