Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
Number of rings
I have the unider 5.8GHz. Its only ringing twice and I need it to ring 4 times before going to the answering machine. I lost the instruction manual. Can anyone help ?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Nov 30, 2012
  • kakima Nov 30, 2012
  • 518 Answers
SOURCE: Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Posted on Mar 28, 2008
SOURCE: Base Shuts Off
You can go to Uniden.com to see the manual for these phones.
Posted on Jul 10, 2008
SOURCE: Increase numbers of ring
If the machine won't go past 4 rings (which it should somewhere in the answering machine settings menu) you could always change your greeting to a message that tells the caller to wait a few more moments for you to answer, while you get to the phone....
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: hOW TO CHANGE THE NUMBER OF RINGS BEFORE THE MACHINE ANSWERS?
This is for a 5.8 GHz uniden. Hit "menu/clock" then use volume up and down key to select number of rings and then below "menu/clock" hit "set". That should it.
Posted on Apr 20, 2009
BillB-SA
  • 2761 Answers
SOURCE: Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Posted on Dec 12, 2009
How do I increase the number of rings on answering machine
The following works for the Uniden models
D1680, D1481, and similar phones:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Ring Time"
press [select]
scroll to the ring-count you want to use
( 2, 4, 6 rings or 'Toll Saver' )
press [select] (chirp) press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Apr 14, 2016 | Uniden DECT 6.0 Cordless Telephone...
How to increase the number of rings on answering machine
press [menu]
press [select]
press [select]
Apr 14, 2016 | Uniden Cordless Phone
Our phone rings only twice and then goes to the answering machine. How do I change the number of rings to 4 or 5. I lost the Uniden user manual.
With the phone in standby mode, press the menu/clock key three times.
You hear "Ring time" and the current ring time, and it is displayed on the main base. Then you hear the guidance for setting the ring time.
Press the volume/select-up-down until the desired setting appears.
Press the set key.
Full instructions are in the "Setting the Ring Time" section of the manual (page 36 in my copy). If you need a manual, you can download a copy at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI5588-2om.pdf
Sep 16, 2011 | Uniden DXA15588-2 Twin Cordless Phone
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual, http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1717-_E
Dec 09, 2010 | AT&T 1717 Digital Answering Machine
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I lost the manual, how do I set the day and time, and rings to answer. It picks up after 4 rings, can I set it for more rings? Thank you
I have this answering machine...
To set the day and time press the "REPEAT" button and hold it in. It will say something like "Time not set." and if you keep holding it it will say, "Monday." Now release the "REPEAT" button and use the "ON/OFF" button to cycle through the days. When it says the correct day, press and releasethe "REPEAT" button. Then it will go on to set the clock and you're done.
To adjust the rings, there is a slide switch on the top where the cords plug in. You can switch it to 2, 4 or TS (Toll Saver). Toll Saver generally lets it ring for about 5 rings before answering.
Nov 24, 2010 | Conair TAD2018CG Digital Answering Machine
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Number of rings
none.
page 16).
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
61 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
