Question about Refrigerators
Either the wires are crossing or the diode is faulty in the water release mechanism of the water dispenser. Ice maker works fine but water dispenser will 'let go' by itself, pouring water on the floor.
  • 2 more comments
  • kathys943 Jun 17, 2009
    We haven't had a problem with water pressure to the dispenser or ice maker in the last year & 1/2. The pressure is there, and the ice maker is working fine. The 'stop/start' is not working. Without depressing (pushing glass onto) the valve, the water will all of a sudden start 'dispensing'.
    Defrost drain is not frozen over. It is something to do with electrical or sensor/message sender.
    This is a Magic Chef, Model RC224PD with total volumn of 21.6 cu.ft.
  • kathys943 Jun 18, 2009
    We managed to keep the wires from crossing by (I suspect) creating a barrier between & this seems to work, so I suspect having a new actuator switch would have solved the problem.
  • 15,935 Answers
Part #2 in THIS DIAGRAM is a switch used to activate the water. (same switch used for ice)
It has failed, and needs replacement.
CLICK HERE to see the part.
Thanks for using FixYa!!
Posted on Jun 18, 2009
    Sergeant:
  • 326 Answers
Your water supply needs water pressure between 30 and 120 psi (207 and 827 kPa) to operate a water dispenser or icemaker. If you already have a refrigerator installed that has a water dispenser, you should be able to dispense about 3 to 6 ounces of water in about 5 seconds from your dispenser. You can better check the water supply pressure by using the water supply line itself. The 1/4" water supply line should dispense at least 9 ounces of water in 5 seconds. If it doesn't, the water pressure to the refrigerator is low.
Posted on Jun 17, 2009
  • SABARI ANAND
    SABARI ANAND Jun 17, 2009
    sounds like your defrost drain is frozen over. When the refrigerator is
    going into defrost it's draining through the front instead of the drain
    pan. You can remove the shelves and peel off the back cover and clear
    the drain by pouring hot water on the frozen drain hole. If you have a
    baster of some sort you could try to squirt the hot water through the
    venting on the bottom of the panel. Another way to to point a hair
    dryer on the drain hole. The best method is to remove the shelves and
    panel and make sure the drain is clear
  • SABARI ANAND
    may i know the exat model no please
I have a ge fridge. water runs out of water dispenser when filling ice maker
Either there's a pinched wire causing both solenoids to operate at the same time or the wires going to the solenoids are connected to the wrong terminals. You can check for a crossed wire by watching the water flow into the ice maker when you dispense water. If water does not flow into the ice maker then the wires on the solenoids are connected wrong. If water does flow then there's a wire pinched.
Oct 21, 2014 | Refrigerators
JennAir JSD2789GES ice maker /water dispenser
if the water is stored in a container matrix in the fridge (to cool it down b4 dispensing) it may have frozen up. best give the unit a complete defrost to see if this is occuring, if so the thermistors may be faulty.
Jul 07, 2007 | Maytag MZD2665HE Side by Side Refrigerator
My Frigidaire ice maker dispenses water when I use the dispenser on the door. I have been told it may be a DIODE issue. Does the LPHS2687KF0 have a diode?
Good Morning Jim,
I understand the ice maker is dispensing water when you use the dispenser on the door of your Frigidaire refrigerator, model# LPHS2687KF0. I also see that you have a Diode kit and are not sure if it would be this that is needed or a water valve that would be needed. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is causing the ice maker to dispense water. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire PLHS267ZA Side by Side...
Water dispenser does not work
Most likely you need a new water valve or water switch. If there is a click when you push a glass against the water dispenser, that is the solenoid opening. If no click it might need replacing. On mine, the water came out slower and slower; replacing the water inlet valve on the back near the bottom fixed it.
Nov 19, 2013 | Kenmore Refrigerators
My ice maker just stopped working. The water dispenser is working fine. I thawed and cleaned the tube running to the ice maker, but still no ice. What else should I try?
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 02, 2009 | Refrigerators
The crazy water dispenser
Yes IF you turn off the ice make it should stop the water from coming out of the water dispenser.
If can you strip and splice a wire you can install a new diode....
1) unplug the refrigerator
2) Remove the back cardboard cover
3) Find the water valve at the right side. wires that go to the water valve you will is a diode
4) cut and splice in the new diode...
Let me know if you do it ,,,
Nov 03, 2008 | Refrigerators
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water comes out dispenser when ice maker calls for water
if the ice makers calling and its comming out of the doorthe valves are wired yhe wrong way around swop the wires from one valve to another. hope this helps
Feb 12, 2008 | Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
