Question about Echo Garden
ECHO HC-1500 hedge trimmer wont stay running cuts off
I own a Echo HC-1500 20'' hedge trimmer that when started it will run for about 5 min. looses power and cut off but will not restart the plug is firing i'm not sure if it is the carb.
Replace the fuel cap.
Posted on May 29, 2010
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Why no gas going into primer bulb
There is a hole some where check prime bubble
May 14, 2014 | Echo Hedge Trimmer Throttle Cable...
Have no spark on my Echo HC-1500 hedge trimmer. Have replaced coil with new but still no spark. Have also by passed kill switch still no spark. What else can I try
Hi, have you tried a new sparkplug? Also did you set the coil to magnet airgap at 8 thou? Also when you say you by passed the kill switch did you do this by leaving the wire off the coil? Because if you did it at the switch end the wire from the coil may be chafed somewhere and earthing the coil. Hope this helps, regards Phil.
Jul 27, 2011 | ECHO, Inc. 20 In. Double Sided Hedge...
How can i test the ign. coil on a echo HC-1500 and also check the flywheel i have no spark and i have unplug the kill switch
pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Sep 23, 2010 | ECHO, Inc. 20 In. Double Sided Hedge...
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
I have a HC-1500 hedge trimmer tested the kill swithch and it tested good, thought it was a bad coil so put a new coil on, still has no spark, should I put on a new flywheel? One magnet on flywheel seems...
take it to local small engine shop and get a free estament from them
they will tell you whats wrong with the unit
also have you tried to hold the coil wire and have a friend pull it over ??
if you get zapped then try replacing the spark plug
Aug 04, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
3,341 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
