Can not get 7.1 channel sound from my DVD/BluRay Players. I use HDMI Connections plugging both the TV ( Scientific Atlantic 8300 HD Cable Box)and the Blu Ray player (LG BD390)into the desiginated spots on the RX V661.
  • kgc1 Jun 17, 2009
    AV Receiver is a Yamaha RX-V661. Don't understand much of your typing. Why would I want to use inferior connections like R-W-Y with this high powered equipment. I'm not trying to be rude but am very frustrated.
    Genius:
  • 1,847 Answers
Let me know the make and model no# of the 7.1 Home theater Sy.?
In the mean time try change the AUX mode and also remove the HDMI and pulg in the audio Video cable (R,Y,W).
Let me know the status..
Thanks
K
Posted on Jun 17, 2009
  • Legin Varghese
    Legin Varghese Jun 17, 2009
    Make sure the connection are all fine (refer the manual that can with the receiver ), and press the AUX button on the remote. It should work fine.
    thanks
    K
Hdmi cable for 40" led TV WHAT ARE THEY FOR
The hdmi cable is used to connect the tv to devices so it can be displayed on the tv. Devices such as, but are not limited to, computers, bluray/DVD players, gaming consoles, etc...
For channels, you have two options.
1. You would need to purchase a cable package from one of the options in your area. They will run a line I to your house and provide you with a cable box in which you connect the cable box to the tv via hdmi cable.
2. You can purchase an antenna and plug it into the tv. Run the channel search and you'll have those channels. Some TVs may have built in antennas but if yours doesn't, I'd go for a simple antenna from target or best buy. Or you can purchase it online.
Thanks!
Sep 22, 2014 | SEIKI Digital SE40FY19 40" LED TV...
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
How do I hook up my surround sound system thru my stereo and tv
connecting your surround sound system is not complicated.things you may need:OLDER STEREO SURROUND SOUND:analog red, white, and yellow cable connectorsHDMIaudio fiber opticsif you bought your stuff new from electronics store,then it would be easier.all you need is HDMI cables (mostly)depending where your inputs and outputs go, you must know the rule. OUT-TO-IN. that means if you are using a cable box, dvd, bluray, playstation, or xbox. everything in these electronic devices are OUT. then connect them to the IN ports of your surround sound. at the back of your surround sound there will be connections saying IN-dvd, IN-dvr etc. connect your OUT DEVICES.
NOTE: YOU MUST KNOW WHAT ARE YOUR CONNECTIONS, LIKE DVD-IN OR DVR-IN CU'Z YOU WILL USE YOUR REMOTE TO CHOSE WHICH CONNECTIONS YOU WANT TO USE.
now from your surround sound to your tv.the same ruleout to in of your tv. You should look for HDMI port that is saying OUT. you will connect your HDMI cable from there connecting to your IN of your tv. remember which port you plugged the HDMI cable as you will switch to that particular input. it will say at the back of your tv in-1, in-2, in-3 or as much as the manufacturer want to have in there product.
connecting your speakers.you must remember the color code.if you chose red as positive, all the red wire must be positive.colour may be different but same idea. if you have sub-woofer it will be an analog cable you will only use single cable. At the back of your surround sound there's a connection saying sub-woofer out.
now selecting your inputs.turn on your tv and stereo.newer tvs and stereos are smart they can configure there system which is turned on.
anyways if you will do it manually, you must select from the remote what is the connected input. (input 1, input 2 etc.) if you found the right input, do the players (dvr, cable box, dvd, bluray, playstation, xbox etc) turn them all on and select from your stereo remote control.note all the inputs you selected.
Dec 31, 2012 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Plug and play on samsung r155 and samsung tv connected to v+ box by hdmi
I HAVE THE EXACT SAME PROBLEM WITH MY SKY + THE DVD PLAYER JUST FINDS NO CHANNELS - DID YOU GET A SOLUTION YET
Nov 20, 2007 | Samsung DVD-R155
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
52 people viewed this question
 Grubhead
Grubhead
