Question about HP DeskJet 932c InkJet Printer
Blinking orange light on hp 932c
The printer works great for a while and then the orange light begins blinking and I cannot get it to stop; i have ink in the cartridge;
  • 72 Answers
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Posted on Jun 17, 2009
The ink icon light is blinking
  1. Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
  2. Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
  3. Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
  4. Select "Setup" on the CD and select "Remove HP DeskJet 932c. The printer software and drivers are removed from your computer.
  5. Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
  6. Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
We are in the middle of printing our Tax Return and an orange light keeps blinking on the top of the printer - and it has stopped printing.
Hi and thank you for using fixya:
On this specific printer model this light means that your paper has jammed, you need paper, or your ink is low. Please re-start your computer and printer and try again. If problem persists check ink levels on the printer settings (computer)
Good luck
Apr 13, 2010 | HP DeskJet 932c InkJet Printer
Refilled ink
its your ink cartridge replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | HP DeskJet 932c InkJet Printer
Ink cartridge light is blinking without need. and won't print
try to unplug the power cord let it set for about 5 to 10 min then plug it back in and turn the printer on should work fine then
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 23, 2009 | HP DeskJet 932c InkJet Printer
Orange light blinking
This could either be out of ink ,out of paper ,paper jam etc.
See if the computer gives any errors on the screen and check your manual(if you still have it)
If none of those solutions help then try the following ,
pull out the power cord and press the power button for about 20 seconds ,then replug and see what happens.
If it still gives an error then it will have to go to HP service center.
Jul 03, 2009 | HP DeskJet 932c InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
355 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
