Question about Video Game Consoles & Games
I need directions for the old x-box - Video Game Consoles & Games
  • 80 Answers
GameStop should have everything you need. You can go to their website at gamestop.com or go to a store. Game Crazy should also have the directions.
Posted on Jun 24, 2009
How do I attach a flat leaf antenna to an older Phillips TV
The old style TV's need a converter box. You cannot just hook up an antenna directly to the TV. The TV signal in the air is now digital. Your old style TV has an analogue TV station tuner. The converter box transforms the digital signal into a usable analogue signal. Just do a online search to find out any information that you need.
Oct 18, 2015 | Televison & Video
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
I need to install new image transfer belt and cant figure out how to get old transfer belt out
There should be directions in the box.
If you would have mentioned what kind of printer, perhaps I could have given you directions.
Apr 17, 2011 | Office Equipment & Supplies
Old electrical box has 3 black wires. new device has 4 colored wires (white, red, green-ground, black - hot), the box does not have a ground wire (that I can see) and the old device only had three wires. ...
Early installations grounded the neutral line at the transformer, but did not bring in a direct ground wire as required for modern installations. White is neutral and should be connected back to the transformer secondary center tap. You will need to drive an 8-foot grounding rod near the panel and bring the ground connection into the box grounding bar (tied directly to the box as opposed to the neutral bar which is insulated from the box). Red and black wires are for 220 volt connections back to the transformer and feed each breaker on that particular rail with 110 volts. Any dual 220 volt breaker will contact both vertical rails. Each light and outlet in the house should have a ground connection, a neutral connection, and a 110 volt connection. Always place a switch to interrupt the 110 volt connection, not the neutral connection. You will likely need to measure the voltage across the suspected two hot wires to confirm the incoming 220 volt lines. Hope this helps!
Dec 27, 2010 | Garden
47 inch Olevia plugged directly into cable no box and will not program. All other old cable ready tv sets work without box
Diffrent tv,diffrent signals,deffrent frequencies.Talk to ur cable company for the box,to many pay tv signals in one area this day,that why need a box.
Nov 05, 2009 | Olevia LT42HVi 42 in. LCD Television
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
How do i inside air filter for 2008 HHR
Open the glove box on the right side of the dash. There are tabs on each side that must be pushed inward to release the glove box, and let it open completely. You may need to remove all items from the glove box before doing this, as most stuff will fall out when you release the tabs, and let the glove box open fully.
You will then see three (3) tabs that hold the cabin filter compartment door closed. Release those tabs to expose the filter. The old filter will slide straight out. Do this slowly, as not to send dust and dirt flying all over the inside of the car. Note the direction of flow on the old filter before removing it. The filter will be marked, "AIR FLOW" and have an arrow indicating this.
Now, simply install the new filter, noting the direction of flow. Close the filter housing, snap the housing tabs closed, raise the glove box back into position slowly, re-installing the glove box tabs, and you're finished.
This procedure is also explained in your owners' manual, on page 3-22, under Passenger Compartment Air Filter.
Apr 21, 2009 | Chevrolet HHR Cars & Trucks
Conecting DVD/VCP to tv through DIRECT SAT. BOX
You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
Feb 26, 2008 | Televison & Video
Video Game Consoles & Games Logo
55 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
