Question about Saeco Incanto Classic Espresso Machine
Can't find circuit breakers on the boiler for Saeco Incanto
Saeco Incanto will not power on. It sounds like a similar problem to the one referenced. I have opened the back, but cannot find the circuit breakers mentioned in the solution to the problem by JohnnyBeans. Can anyone tell me where to find these breakers? Thanks for any help you can give.
  • 1,089 Answers
Hi
It depends on which boiler you have. If you have the round boiler (looking from the front top down, they will be on your left side). They will be on the bottom left side of the boiler. There are 2 of them on the round boiler and there are 2 wires to each thermostat. The button is between the 2 wires on the thermostat. You need to push both buttons. If you have the square flat boiler there is no reset button but a thermal fuse on the back side of the boiler. You have to remove the steam boiler ( horseshoe) to work on the flat boiler. FUN
Posted on Jun 17, 2009
I have an incanto sirius espresso maker and cannot get the screen to come on. As soon as I plug it in the boiler overheats (too hot to touch within 10 seconds. Could this be the overall failure I am h
Sounds as though there is no water reaching the boiler. Does the pump run when the machine is first turned on? Is there a water filter in the feed line from the water tank that may be blocked?
If the pump is not running at all, it would pay to check if there is voltage reaching the pump motor (BE CAREFUL! Only do this if you know exactly what you're doing)
If the pump is running OK, the water filter is not blocked and all the hoses are in their correct positions and not kinked or detached, then the only really likely thing left is that the boiler is blocked with scale, stopping water from entering the chamber
Nov 07, 2013 | Saeco 00034 Incanto Sirius Super Automatic...
My saeco incanto shows "heating and rinsing" in the display but is going nowhere from there
Check the Breakers on the boiler. Most newer machines have the breaker against the boiler which can be reset.
Important --- Please make sure the machine is unplugged before attempting this.
www.CeriniCoffee.com
Aug 30, 2013 | Coffee Makers & Espresso Machines
Saeco Incanto Sirius doesn't turn on. Outlet fine. Is there a main fuse to check/reset? Other suggestions. Hopefully it didn't get surged with Hurricane Irene.
We have here the map with service support but as you can see they to have for the moment any at CT. However you can check if any other area is the best for you.
Sep 01, 2011 | Saeco Incanto Sirius Fully Automatic...
My Saeco incanto doesnt steam
HI You have a ruptured hose going to the boiler. Needs to be replaced. Yes you can fix it your self if your handy. Remember to remove all the beans before trying.
Feb 09, 2010 | Saeco Incanto Classic Espresso Machine
Saeco incanto rondo boiler reset
There are thermostats (2) on the side of the boiler colsest to the side of the machine. There is a reset button on each between the wires terminals. Push both.
Dec 11, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco Incanto Classic has no sign of life. Has horseshoe type heater, fuse has continuity. Power switch tests ok. May have experienced power outage.
Hi
There are 2 boilers in your machine. There is a main boiler on the left rear of the machine. It should have 2 thermostats that each have a reset button. The buttons are between the 2 wires on each thermostat. They are on the outside of the boiler between the boiler and the outside of the machine. Push the buttons and then try again.
Oct 23, 2009 | Saeco Incanto Classic Espresso Machine
Water leaks from my Saeco Incanto after brewing.  It appears to be coming from the boiler or back of unit.  I also here a hissing sound which makes me believe that the water is in contact with a hot...
I think you have to replace your bolier in the machine.
If it is the boiler and you replace it, make sure to descale your machine regulary.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto power loss.
You either have two things i think, my first thought is a leak.
The two most usall leaks on a incanto is either from the boiler or the steamvalve.
alitle more long shot is a defective fuse on the bioler.
Jul 22, 2008 | Saeco Incanto Classic Espresso Machine
The curcuit breaker on the boiler probably tripped. There are 2 of them on the boiler. You can remove the back cover to access these parts. If you are not comfortable with taking the machine apart, take it to a service center.
Check out www.CeriniCoffee.com
Authorized saeco service center for new york
Oct 25, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
778 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
