Question about Dell Latitude D610 Notebook
Crt/lcd cabnot get screen to turn on. Don't know how I turned it off.
    Problem Solver:
  • 10 Answers
Is there a fcn button on the bottom left should be blue i believe then look for other keys with blue on them there should be one with a monitor looking thing on it hold down fcn r fuction button down and other button at same time if this doesnt work try conecting and external monitor to it and see if it works there you will see what the fcn button will do
Posted on Jun 17, 2009
How to clean screen
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don't ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don't pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Nov 01, 2012 | AOC e943Fwsk 18.5" Widescreen LED Monitor
Come to work Monday (today) and turn on monintor , light up for a second and then off and now will not come on. Used another monitor on pc , no problem. This is the second monitor that did it to me.
is this a crt monitor or a lcd monitor? if it is a lcd monitor then your problem is a bad back light power inverter board and needs to be replaced. if it is a crt monitor then check the brightness and contrast controls on the crt monitor.
also check to make sure that the display are compatible with the crt monitor as well! meaning that if the crt monitor's max resolution is 1024x768 and your video card is set to a higher setting then you will get a blank screen with a sometimes green power light, maybe flashing. be very careful though because may also damage the crt monitor. also check your video card setting to make sure it is at 50 hz or 60 hz some crt monitors don't like the higher vertical refresh rate.
one last thing is the age of the crt monitor, it may be on its last leg of life. when i worked at a monitor repair center a few moons ago there was a life expectancy of maybe 30,000 hours(?) on a crt(note: it's been awhile so please don't quote me on this life expectancy!)
you may get eye strain with higher than 60hz range.
Aug 22, 2011 | Westinghouse Computers & Internet
K957ws500 stays on for about 30 minutes then the screen shuts off the light blinks on the display
You have a bad convergence board, or the TV processor has garbage in ti, and if you leave the TV unplugged from the wall, for 40 MIN. that will reset it back to normal. If that don;t work then it is the convergence board, unless if it turns real blue, or green before shutting down, then that color , the screen voltage needs turn down, then it will stay on. Or the red, blue, or green CRT is sorting out, then it is time to buy a new LCD, if it is a bad CRT. for a service call it will run around 70 dollars to find out. Take care.
Jan 09, 2011 | Sony KP-57WS500 57" Rear Projection...
No video in the display
gues the LCD display is not working,
1 the LCD screen is out or
2 the backlite inside the LCD screen is out or
3 the invertor board behind the LCD screen inside is out.
May 05, 2010 | Toshiba TECRA M9 Notebook
Turns on, no video.
How do you know it's recognizing the input? Black screen on a CRT monitor usually mean the horizontal output circuitry has failed impeding the flyback from producing high voltage. If this monitor is really important to you most reputable repair people still repair them. However, it may be overall cheaper in the long run to dump it and get an LCD monitor.
Feb 25, 2010 | LaCie Electron 19" CRT Monitor
My screen turns black when i turn it on it flashed the creen for
first should do is first try to trim the monitor or meaning mounting a LCD or external CRT monitor to see to fix laptop are behind
Jul 22, 2009 | Computers & Internet
SCREEN WONT TURN ON
Connect an external monitor (CRT or LCD) to the laptop's "VGA-out" port. Then, turn your laptop on. Does it show the usual "start-up" screen, on the external monitor? If so, then either your laptop's screen is totally-dead, or the "LCD-inverter" (a $20 part that takes $50 for a technician to replace) needs replacement.
Or, does your laptop have a key-sequence (LCD-screen-only, LCD-and-external, external-only) that needs to be used to select LCD-only mode?
Apr 23, 2009 | Computers & Internet
Cleaning monitor
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Dell Latitude D610 Notebook Logo
93 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
