Question about Gateway 450ROG Notebook
Laptop Shuts down to black screen without warning.
I have a gateway laptop that just shuts down out of nowhere and we have to hit the power button in order to get it working again. What should I do?
  • 37 Answers
It may be over heating !!
turn it on and run it till you hear the fan turn on, then check if there is much air coming out of it.
if not use a vacuum to **** air throw it as you blow hard into the slot that the air should come out of
Posted on Jun 19, 2009
My del studio laptop doesn't shut down
You could have a corruption in the script or a process that won't stop. Try holding down on the power button until the screen goes dark and all lights go out. That is a hard shut down without saving settings. After it shuts down (finally) power it back up. Hit the F8 key on your keyboard the moment your machine goes to the black screen before it can load windows. That is the safe mode. Move the highlight up to safe mode or safe mode with networking and allow it to continue to boot up. Then, when it's completed the process and windows displays that it is in safe mode, do a normal restart. That should resolve the issue.
Oct 22, 2013 | Dell Studio 1737 Laptop
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
Dec 01, 2012 | Computers & Internet
My Acer z5600 just shuts off while I'm doing something without any notice.I gets very hot at the top of the screen and then shuts off without warning.The screen just goes black and I can not turn
Your processor is overheating. Or the fan for the CPU is dead or the way to eject the warm air is blocked. Try to work with your laptop on a table, if the problem persists, is the fan other way you have to work everytime on the table.
Aug 06, 2012 | Acer Aspire Z5600 PC Desktop
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
Runs good but for random shutdown without any warning,,,
powerdrain pc first. remove battery and ac adapter then press down power button for 15-20 sec. turn it on and check if it will still shut down. observe if it is hot to touch before it shuts down, might also be an overheat issue. if so, need to replace fan and heatsink.
Apr 08, 2010 | Gateway 4540GZ Notebook
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Shuts off randomly
Hi
Have a look at your power settings
Start -> settings -> control panel -> power” settings” (don’t remember the English word)
Here are your settings for with or without the power supply.
/Teis
Was this helpful, then don’t forget to vote
Dec 15, 2008 | Toshiba Satellite A35-S1592 Notebook
Shuts down
thank you for your response....I'm using Vista and the power seems to be on but the screen is down. I have to hold the power button down for 10 seconds to shut down then turn it back on to restore the computer. It is a Toshiba A215-S5818
Jun 18, 2008 | Toshiba Satellite A215-S5822 Laptop
Gateway 450ROG Notebook Logo
128 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
