Question about GE 24 in. GHDA986KSS Built-in Dishwasher
GE 530 built in dishwasher does not fill with water
GE 530 dishwasher is not filling with water. If I put water in the dishwasher, I can hear the element sizzle and the water then drains out during the cycle.. just doesn't bring in any water. What do I check? Thanks!
  • 111 Answers
Water valve and level switch
Posted on Jun 17, 2009
Water fill solenoid receives only 10 volts on normal cycle-not enough juice to open solenoid. Dishwasher does not fill. Dishwasher works fine on short cycle because on that setting the control panel...
It's most likely the timer set the timer to when it is gonna fill to a normal wash hook up a volt meter when it is in its fill stage make sure it is putting out 120 volts
Mar 18, 2013 | GE Nautilus 24" Built-in Dishwasher
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Acts like water is turned off to machine. turns on to run cycle but no water comes out. valve is on
Turn the water valve off, and remove the hose. Where it screwed on, there should be a filter screen. This is more then likely to be clogged up. Clean this and try again after you put the hose back on.With the dishwasher in the fill position, and still pulled out, you should be able to hear the water fill valve coil open up.If you still have no water after cleaning, more then likely your fill valve is clogged or the coil has failed and needs to be replaced. 120volts,ac.Please let me know as I am here to help you. Good Luck, Shastlaker7
Nov 06, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Water won't fill, it run through the cycles though
Jun 06, 2009 | GE Nautilus 24" Built-in Dishwasher
The dishwasher will not fill with water. I hear
the main water solenoid isn't opening.  It could be bad or the connection may have come loose.
Mar 14, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 24 in. GHDA986KSS Built-in Dishwasher Logo
331 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
