Question about Yamaha 12V Air Pump
1998 GP1200 Engine start problem?
I havn't rode it for over a year, I charged the battery, drained out the old gas. 1st tried to start & it wouldn't turn-over at all. Put battery charger on "Boost/jump" mode & engine turned over a few times. I unhooked the Batt. re-charged it & let it sit for 15 mins. When I started to hook the Batt back up (blk lead 1st) when I put the red lead on the Batt post it sparked & the engine turned over! Is this a starter relay/solenoid problem?
    Champion:
  • 207 Answers
Your starter brushes are stuck you can try tapping the stater to unstick them but u will pobally need to replace the starter u can get it on ebay
Posted on Jul 08, 2009
Where should I start on a motorcycle that has been sitting for 20 years?
Hi Nick:
What a great project.
- I'd start with a really thorough clean up.
- You've mentioned the gas. Definitely, drain the tank, hoses, carbs, and clean the carbs. If there's a filter I'd change it.
I wouldn't even try to run it without cleaning the carbs first.
- Replace the battery, oil, and spark plug.
- Engine coolant?
- Tires? I wouldn't worry until I had it running but definitely replace.
Patience & time. You'll have an excellent bike.
Jul 13, 2015 | Honda Motorcycles
Battery drained after use
A lot of automotive parts stores will check a battery for free...
find your lowest amp rated (less than 10) and charge it over night.
Have battery load tested.
if good, place ammeter between battery and the rest of the tractor to check and see if load from running engine is draining or alternator isn't working.
or fast way to check an alternator on almost anything, start with battery, the pull off the negative (black) cable, if engine dies nothing is powering the engine but the battery (on an alternator driven electrical system, the battery is only used to start the engine)
May 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Rode home new 883;, next morning bike wouldnt start, battery weak. would not turn engine over. bike is 2009 with 40 miles, bought from dealer
how old is your battery? if it is 2 to 3 years old it may need to be
replaced . charge it up and see if it keeps charge, crank your bike
run it for a short time 4 or 5 min. shut it , and try to start it. if it
drags when cranking go buy new battery.
Nov 01, 2010 | 2006 Harley Davidson XL 883L Sportster
Because of extensive travel, my bike has been basically sitting for the last two years. I just put in a new battery in it and the first time I rode it it rode great. Now the warning light (don't know...
The indicator icon or light you are seeing is most likely the "check engine" light, and if viewed closely looks like a tiny engine. A review of the owners manual might be helpful. Fuel that is two years old is not going to combust/burn properly. I'd start with draining the fuel tank and putting fresh gas in the bike. If you installed the new battery yourself double check the terminal connections and look where the negative cable ends on the vehicles frame. Many electrical malfuctions can be traced to bad "grounds"or loose connections.(the bouncing on the seat). Take some time to look carefully around. The vehicle's ECM (Engine Control Module) is capable of storing one or more "trouble codes".
Aug 09, 2010 | 2004 Harley Davidson VRSCB V-Rod
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Katana died with full charged battery
SOUND LIKE VOLTAGE REGULATOR IS NOT WORKING CHARG BATTERY AND GET VOLT METER AND START IT UP AND HOLD RPM AT 1500 AND YOU SHOUL BE SHOWING 13.95 OR MOOR HOPE THIS HELP IF NOT AT LEAST 13.5 VOLTS THEN YOU MAY HAVE BAD VOLTAGE REGULATOR
Aug 19, 2009 | 2003 Suzuki GSX 600 F (Katana)
'01 929 Erion Edition charging issues can't start
start saving some $$$$$$ as i think the charging system is in need of repair or replacement!
buy a multi tester & it will have a good manual with it!
Cheers rob
Aug 11, 2009 | 2001 Honda CBR 929 RR Fireblade
Battery Drain when parked.
First off, how old is the battery? It is possible it might be stratified and its just no longer holding a charge well. I've had batteries that are 2 or 3 years old and then they just go dead if I don't start them up every day or so. (Some batteries are just made better than others) If the battery is brand new, then check for some possible wiring shorts. Try looking at the engine running in the dark and try moving around the wiring harness to see if by chance you see any sparks or arcs of electricity. Other than that, you might have to have a qualified auto electric mechanic to check it out for any abnormal power drains.
Jul 30, 2009 | 1995 Dodge Ram 3500
1998 GP1200 yamaha jet ski won't start
When replacing battery in yamaha GP1200 when attach negative cable the unit seems as wants to turn over the engine while the unit is off and no key in place.. also notice in seconds that the battery terminal on negative side started smoking..actually melt the new battery terminal on negative side..yes, postive was connected to positive. Any ideas what why this would take place??
Jul 15, 2009 | Yamaha 12V Air Pump
99 volkswagen passat starts, then stalls, won't keep idle
I am having a similar problem on a 2003 Volkswagon Passat 1.8L 4 cylinder manual engine. My batter (after 10 years of service) died about a month ago. When the engine is cold and I start it up the engine (if I do not carefully add gas to rev the engine) will idle at around 200 to 400 RPM and then stall. The problem does not occur after the engine has been going for more than about 90 seconds. No check engine light is on. Ideas anyone?
Oct 18, 2008 | 1990 Volkswagen Passat
Yamaha 12V Air Pump Logo
572 people viewed this question
Top Yamaha Water Sport Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
