Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
Ice maker Whirlpool model ED5GTGXNB14 iCEMAKER SLOW IN MAKING ICE CANNOT FIND THE WATER FILTER TO CHANGE IT. iT IS NOT A YEAR OLD
  • 111 Answers
Filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Posted on Jun 17, 2009
Whirlpool refrigerator icemaker is not making ice
When the ice tray is full it pushes 'UP' a lever, which stops the water flow. It may be stuck in that up-position.
Jul 01, 2015 | Whirlpool Refrigerators
Ice Maker not working after replacing IceMaker and Inlet Valve. Any other ideas?
Hi. I am sorry that your ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
Jun 19, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
