Question about Maytag Neptune MAH5500B Front Load Washer
Odor, mildew around rubber ring, swooshing standing water in tub
I have had musty odor from washing machine when door is opened. I found mold, mildew around rubber ring, and before I wash if I spin the washer inside, I hear water swishing around. I have been getting all sort of allergic reactions and now do not know what to do with this machine. I have washed it through with chlorine and the problem persists. I consider it a health risk. any solutions to these problems?
  • stasie120 Jun 17, 2009
    I'm a senior citizen and don't know how to take the tub out....I'm really distressed. Maytag recommended that I use "Affresh" tablets...Will try this.
  • 111 Answers
Take the tub apart and then you going to find much more mildew let me know after
Posted on Jun 17, 2009
  • Joe Povoas Jun 17, 2009
    you can try but its not going to work , but try anyway, the problem is you have excess of soap residue attached to the metal parts of your drum , and the smell comes from there
Have you tried washing it out with vinegar? a couple of cups and a hot wash should do the trick
Posted on Nov 29, 2009
    Problem Solver:
  • 12 Answers
After washing it out with the vinegar, shake baking soda into a few of your washes. If you can, leave the lid open after each load. This will allow it to dry out and not allow all the moisture to just sit.
Posted on Dec 04, 2009
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
Odor in washer tub
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Apr 05, 2010 | Speed Queen AWS45NW Top Load Washer
Musty odor in front load machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%$$
Mar 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!##
Dec 26, 2009 | General Electric WCVH6600H Front Load...
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Musty smell from rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 23, 2009 | LG WM-2277HW Front Load Washer
My Elite washer has a musty odor. I have run an
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
637 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
