Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Noise of fan
My cpu fan makes much noise.please give me some tips
  • blueextc3221
    blueextc3221 May 11, 2010
    Once a bushing fan starts to make noise - it is too late.
    Only replacement will solve the issue.
    Sometimes you can remove the sticker on top of the fan, and put graphite/oil mixture to quiet the bushings - however it will need to be done regularly.
    President:
  • 2,653 Answers
Clean the fan with compressed air, and a q-tip.
If it still makes noise, replace the fan. They're cheap.
Posted on Jun 17, 2009
Why Pc do not BOOT WHEN Power is there?
Give me some more details, please. Does the computer make any noise? any beeps? do you here the fan on your CPU, GPU, SSD, or other fans go on? any flashing lights?
Aug 28, 2014 | Computers & Internet
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
Cooling fan makes loud noise upon starting machine, its not even a year old
Open the side panel of the computer. The inside of your eMachine must be like this:
The only fans in the case are the one inside the power supply and the one over the cpu heatsink. Take a look for something like cable or tire-up to come too close at the cpu fan. In this case take away this cable or tire-up and keep it in a safe distance. Try the results. If the problem is still active try this tip very carefully. Use a drinking straw as brake for the cpu fan. Hear the difference in noise. If the noise is dissapeared your cpu blower needs replacement. KEEP IN MIND THAT YOU MUST NOT RUN THE PC WITHOUT CPU FAN FOR MORE THAN 5 SECONDS. OTHERWISE YOUR CPU WILL BURNED.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 02, 2010 | E-Machines eMachines T3830 PC Desktop
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
It always gives a noisy sound. i cleaned it twice and remove dust. but it still comming. i hope its comming from indide the fan like motor. pls help me on this
If the CPU fan is making funny noises then its because the bearings are worn out and the cpu fan needs to be replaced. It has to be the fan cause you already go rid of the dust and dirt from it.
Aug 10, 2009 | HP Compaq (216472001) CPU Fan
Cpu
The noise is coming from fan friction and vibration. Running compressed air through fan components can help reduce noise pollution from dust buildup. Brush-less CPU/GPU fans are significantly quieter than the brush-motor powered fans that come with some factory electronics. Furthermore, some computer cases are designed with noise reduction in mind; Antec designed cases are know for being one of the quietest because they use patented bushings to secure the computer hardware. Moreover, make sure internal wiring is free and clear of all fan blades.
Mar 11, 2009 | Intel D101GGC Motherboard
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Crazy fan nosie
Noise from computer You should only expect to hear a slight hum from the CPU fan; below are some issues that may cause additional noise from your CPU fan.
Click on the above link , follow instruction, Good Luck.........Please dont for get to Vote.Thank You.
Dec 15, 2007 | E-Machines M2352 Notebook
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
