Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Unit stops heating and must be unplugged to 'reset' once a week.
Rheem PVS50 is 1.5 years old and just stops heating. Remove the elec plug and wait for 15 secs and it starts up again for another week. I did not notice a blinking light code. I was advised to gently clean the temp sensing probe with fine steel wool and that allowed the unit to run for 6 wks. Problem just returned. May be coincidental, but this often occurs over the weekend when usage is lighter.
  • 332 Answers
Do you have alot of suit in the flue??? take the flue off and clean it then clean the burner assembly and see if this doesn't help you
Posted on Jun 21, 2009
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
2 yr old ecco sense UMC 117 unit flashes 38 beeps and wont give hot water
1) Copy following link for Rheem tankless troubleshoot, including ecosense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Probably needs new circuit board.
3) Product manual usually give list of required yearly maintenance.
Perform the maintenance, just like changing oil on car, and then service technician is familiar with your water heater and can count on your money each year around Christmas.
4) For independence, reliability, cost, and convenience, don't buy tankless water heater, or any other expensive/complicated water heater that requires yearly maintenance, and generally cannot be repaired by homeowner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 04, 2013 | Rheem Tankless Water Heater Main Remote...
I have a Rheem 50 gal smartwater ignition system tank that just stopped heating--it's 10 years old
If it just quit the first thing I would do is to make sure that the breaker is on .Then take then screws out that hold the cover plates on the side of the heater. Carefully spread the insulation apart and you should see a small red rest button . Push the button in and if it goes in and stays there wait for awile and see if you have hot water. About an hour and you should be getting there. If the reset button goes in but pops right back out when you let go of it then you either have a bad reset or possible a bad element.
If you have a volt meter you can check incoming power on main terminal block and at each element.Remember that this is a 240 volt unit so be careful. Also see what the thermostat is set at and turn it up if you can.
If you can get it going again it would be to your benefit to flush your water heater out. By draining and flushing you can extend the life and effiency of your heater. Thank you
Feb 21, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
May 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
635 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
