LCT27HA36 TV won't power up
Red standby light stays on and doesn't respond to th remote or the button on tv.
    Problem Solver:
  • 5 Answers
New battery cord needed
Posted on Jun 17, 2009
Panasonic plazma tv th-42pd50u. Red light automatically turns on when connected to power and stays on. No clicks, No blinks and No picture. Is this a faulty power supply board?
possible reasons, its in standby, hold in the proper ON button on the tv for up to 20 seconds gently. or try disconnect power(pull plug out) wait 10 seconds, plug back in and turn on using the actual button(holding for up to 20 seconds) NOT THE REMOTE if that does not work, make sure your INPUT is CORRECTLY selected eg you are viewing HDMI1 and NOT HDMI2 for example. there may be different procedures for flashing lights
Dec 12, 2017 | Panasonic Televison & Video
Philips LCD TV Red Light Stays On, TV won't turn on or respond in any way
Could be power supply failure or you may not be using the "hospitality" remote.
Aug 13, 2014 | Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Need a four digit code for comcast universal remote for panasonic th-42px80u
Hello
Four digit universal remote codes for Panasonic TV are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 27, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Oct 01, 2008 | Televison & Video
The tv wont start
there is an input button. Press this button untill you reach the input that you plugged into.
Jan 05, 2008 | Panasonic TH-50PX75U Plasma HDTV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
