Question about Camera Flashes
Quantaray QBX-8000xi owners manual
Question 1 - Will the Quantaray QBX-800xi work with my new Sony Alpha 100 DSLR?
Question 2 - Is there somewhere I can find an owners manual  I would prefer a download, but if there is somewhere I can get one via snail mail, I would appreciate an address.
    Brigadier General:
  • 3,006 Answers
Re: Quantaray QBX-8000xi owners manual
1. No.
Unfortunately not.
This flash is a superb budget alternative to the Minolta alternatives but is only suitable for their film cameras. Sony's SLR's are based on the later Minolta Digital SLR's and they're all incompatible with this flash.
The technical differences between the film and digital Minolta cameras explains why a Minolta 5600HS (for example) had to be redesigned and redesignated as a 5600HS(D). The former will not work on Sony Alpha models, but the latter is fully compatible.
2. I haven't managed to find a manual for this model in my stock room and failed to trace one online.
Posted on Jul 04, 2009
0 characters
3 Points
Yes and no. It will work fine as a manual flash, putting the burden of figuring out correct exposure on your shoulders. It will work fine in the automatic modes on a Nikon camera.
Quantaray makes a Canon version of the flash which will work in the automatic modes on the Rebel XSi.
Jul 27, 2010 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Doesn't work with canon d40 digital camera
You may have identified your own problem.
Your camera is either a Nikon d40 or a Canon EOS 40d (aka Digital Rebel), there's no such thing as a Canon d40.
If your Quantaray flash has the wrong brand dedication module on the bottom for your brand then it won't work properly (if at all).
If this is not the cause, then please be more descriptive: does the flash power up at all, will it work with other cameras, do other external flashes work on your camera? You may just need to go into the menu and enable the hotshoe.
Click here as well if you lack an operation manual: Quantaray products are always a pain to find manuals for as they're badge-engineered models supplied in the USA by Ritz/Wolf. The trick is always to find what the individual product is usually sold as. In your case, it's a ProMaster FTD5700. Page 2 of the manual will help you to identify which dedicated module you need for this flash to work with your camera.
I hope that I've helped, if not then please report back with additional details, or if I've helped you to solve your problem then please take a moment to rate my answer.
Feb 14, 2010 | Quantaray QTB-9500A TTL Flash
To what extent is this flash dedicated to Sony DSLR?
The flash will provide all the automatic features with the Sony dSLR. With other SLRs, digital or film, you'll have to use it in manual mode.
Feb 02, 2010 | Vivitar DF383 TTL Flash for Sony
How can I get the Quantaray QTB-9500A to work with the Canon rebel XT? It worked fine with my ellanIIE. Can I order a new module? Thank you for the help
You'll need the "AF module CN", but as the flash is no longer made will have trouble finding one.
It helps if you search for the correct flash model as Quantaray is a no-name bit of badge engineering for Ritz/Wolf.
Your flash is really a ProMaster FTD5700.
Please don't forget to rate my answer.
Sep 25, 2009 | Quantaray QTB-9500A TTL Flash
I hav a Quantaray 9550 with a module to fit a Minolta Maxxum xtsi. Can it be used with a sony alpha?
Yes, it can, but you will likely loose some of features that make the 9550 such a nice flash.
Better bet, contact a dealer for Quantaray and buy the Alpha module.
Aug 22, 2009 | Camera Flashes
I have a plan to get PENTAX AF 500 FTZ flash. i have a doubt if this model will be fine working for my sony alpha 200 DSLR. kesavan b
Check the configuration of the hot shoe on the flash AND the camera. The only issue you should have, is setting up for the heat range and the syncronizing speed.
Aug 10, 2009 | Pentax AF-500 FTZ TTL Flash
Quantaray QDC-900WA
Quantaray appears to not be a company at all It is affiliated with Ritz Camera and neither Quantaray nor Ritz actually manufacture anything.
The Quantaray SLR lenses are made in the Sigma factory. But many feel that they are not equal to the Sigma branded lenses.
I haven't found the maker of the flash units, yet. I should learn more this evening. An interesting mystery.
In here, you can find the User Guide for Quantaray 900 for Nikon TTL Flash
Good luck.
Jun 16, 2009 | Quantaray QDC-900WA for Nikon TTL Flash
Fuji s7000
Thanx to forum input I found a Quantaray qb-350a flash with a single contact on the hotshoe. By turning on "external flash" in the Fuji s7000 allows the Q350 to work beautifully and for about $40 bucks. It also works on earlier Fuji's like the 6200.
Mar 20, 2009 | Quantaray QTB-9500A TTL Flash
Quantaray PZ-1 DSZ and Sony alpha 100
Having the same problem with the Quantaray 7500A and my Sony Alpha 200. I either have to go to full manual or overexposed. I've sent off a few emails to Ritz but still haven't gotten a reply.
Jul 30, 2008 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Owner's manual or instructions?
Hey Guys -
I too had a similar situation and was told to contact Ritz Camera (I Googgled it). I also contacted the following company and finally got a manual:
Sally Wall
Customer Service Supervisor
Tocad America, Inc.
53 Greenpond Road
Rockaway,NJ 07866
973-627-9600 x115
Fax 973-664-2438
Sally Wall []
Apparently, my flash, QUANTARAY PZ-1 POWER ZOOM Flash unit , was sold under another name, PZ4000 Af. Hope this helps. If you have the same unit as me, conatct me at and I'll be happy to send you the manual that was provided me.
Apr 15, 2008 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Camera Flashes Logo
556 people viewed this question
Top Camera Flashes Experts
Level 1 Expert
Are you a Camera Flash Expert? Answer questions, earn points and help others
