Question about LG WM2688HWM TROMM SteamWasher
Same problem PLUS another one
Does anyone else have liquid detergent leaking out and running down the front of their washer?
    Problem Solver:
  • 5 Answers
Buy a new water hose
Posted on Jun 17, 2009
I have a lg tromm wm2277hw washer Why does it leak soap down to the front of the washer
in my experience you would be much better off using powdered detergent instead of liquid. it will stop leaking down front and will not leave residue in tub that eventually leads to mold mildew issues.
Jul 18, 2015 | LG Washing Machines
Liquid detergent & fabric softener leaking down front beneath door. why?
depends on the model you need to replace the door boot
Jan 20, 2015 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I have a lg wm2277 front load washer and the liquid soap cup gets clogged and when I open the tray after the load is finished, it will be full of water. I have tried cleaning the cup but the white stuff...
Switch to powdered detergent. You'll be much happier in the long run. Liquid detergent leaves a residue. Eventually the residue mildews. Powered detergent leaves no residue. Plus you will solve your current issue. Also skip the softener and use plain white vinegar in its place. The vinegar helps eliminate mildew and it also helps release Dey from your clothes in the rinse cycle.
Jan 06, 2018 | LG WM-2277HW Front Load Washer
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
