Question about Toshiba Tecra 8200 Notebook
Toshiba Tecra 8200 Laptop. when i type on the Keyboard some Characters do not work. A,D,E,I,K,L,P,R,S,T,U,W,X,Y,Z, and Back space do not appear on the Screen, all the rest are ok.
  • cjmaryan Jun 18, 2009
    Thank you. I`ll go for a new Keyboard. Colin.
    President:
  • 2,653 Answers
You probably need a new keyboard, but before ordering one go into the control panel, device manager and uninstall the keyboard.
Restart the computer.
If you get the same results, it's time for a new keyboard.
You can get a replacement from ebay for cheap and install it yourself. Usually it's 3-5 screws. very easy diy project.
Posted on Jun 17, 2009
Tecra 8200 password
use bios password code for reset bios password
Removing BIOS password on Toshiba Satellite Laptop - YouTube
The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from
Jun 18, 2014 | Toshiba Tecra 8200 PT820U-OFG8C801...
Toshiba laptop tecra 8200 wifi drivers need to install
try on this page
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073794567&rpn=PT820U&modelFilter=8200&selCategory=2756709&selFamily=1073768664
Feb 19, 2011 | Toshiba Tecra 8200 PT820U-OFG8C801...
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
When i am typing , the keys are automatic got a space even i didn't using the space bar .
Hi Friend, In this case i would recommend you to please try connecting the external keyboard to the system and check if you have the same issue with the external one as well.
If the external one works fine then I believe there is a need to reseat ( disconnect and reconnect) the keyboard.
Dec 09, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
Don
Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Toshiba tecra 8200 power problem
The power button is on the LEFT side of the computer, under the Ctrl key, slightly closer to you. It is covered by a sliding door which slides BACK to open and expose the push-ON button.
Jun 13, 2009 | Toshiba Tecra 8200 Notebook
Turning it on
look for the pwd button dude or atleast give me the model no so tht i can look it for u and let u know
May 22, 2008 | Toshiba Tecra 8200 Notebook
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
Toshiba Tecra 8200 Notebook Logo
223 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
