Fuses OK, Fan OK, blowers OK but compressor does not kick in. Not cooling now. How to get a replacement unit. Sleeve Ok and remains in place, just need the unit that slides in Chuck Raney 12013 Edgewater Rd Fort Smith, AR My AC man say compressor locked up and not working anymore.
  • 334 Answers
If you can give me the make and model number, I can probably locate one for ya.
Posted on Jun 17, 2009
When i turn on the ac no air blows throw
Go to the fuse block and check 15A fuse D which feeds power to the blower motor. Then check 10A fuse K which feeds power to the blower relay and the fan (blower) speed select relays. If the fuses check OK, the blower relay, the fan switch or the speed control relays may be defective. also, the fan speed resistor may be defective
Oct 17, 2012 | 1993 Nissan Pathfinder
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
Fan not coming on with or without aircondition and
Engine fan will only kick in when engine is hot and needs extra help in cooling down, If it doesn't come on so long as engine temp remains ok i shouldn't worry about it too much..
Jun 22, 2010 | 2001 Volkswagen Golf
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
Fan does not kick on occasionally. compressor comes on but sometimes the blower fan doesn't. has happened twice. turned system off then back on and it was ok. next time that didn't work but worked ok the...
there is a seperate relay for the fan motor - switching fan on thermostat from auto to on will help locate relay - on newer units the fan is on time delay on - still a relay problem
Sep 24, 2009 | Carrier Heating & Cooling
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 30, 2017 | Kenmore Heating & Cooling
Cooling has stopped
Apparently the freon has escaped or the metering device for the freon is plugged up. Either way, it's expensive. Check your warranty for "sealed system" repairs.
Jul 26, 2008 | Frigidaire Heating & Cooling
Fedders Window AC
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Aug 16, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
