Question about HP PSC 750 All-In-One InkJet Printer
Found paper but won't reset. cartidge seems to chatter
  • 72 Answers
Performing a cold reset of the printer To cold reset the printer, perform the following:
  1. Power off the printer.
  2. Unplug your printer
  3. .Open all the printer doors and the close them
  4. Plug your printer back in.
  5. Turn it back on
  6. That should reset it
Posted on Jun 17, 2009
Lexmark all-in-one has error message for cartridge stall.
there maybe stuck little paper or something inside the device or maybe the cartidge is broken or the holder of the cartidge i think an expert should see it .. it must be seen and heared to solve it and try to clean it from inside
May 17, 2014 | Lexmark X1150 All-In-One InkJet Printer
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Paper jammed and has switched itself off now can't switch it back on? how can i get it back on?
Well, 1st you should tell what typeof printr you have ,
1- open all doors and remove all the turned paper , there isare keys and sencers are available in the printer will not be active unless in normal case .
2- mean drawer of paper should be checked also .
3- open cartidge and check if there is any trouble in the paper slide way .
2- reset the printer
Oct 28, 2010 | HP Office Equipment & Supplies
Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Jan 17, 2010 | Dell 948 All-In-One InkJet Printer
Getting an infocode message 007 for paper jam, can't see a paper jam and don't know how to reset
Take out the toner cartidge, Remove and throw away the swinging drum cover, you don't need it . It causes jams if loose.
Oct 02, 2009 | Kyocera Office Equipment & Supplies
Check paper tray check cartidge.
I have the 1350 all in one, and when I changed my cartridges I screwed up and replaced both at the same time, that was a no no as I found out. I kept getting the test printer and print example too. so what I had to do was Uninstall the printer and drivers, then reinstall them again, that worked.
Oct 28, 2008 | HP LaserJet 3015 All-In-One Printer
C46 printer
I could not find the manual, but I hope this helps:
I'm not sure if the waste ink pads are in the same place as the c45, but i hope this helps.
Locating the waste ink pads was pretty easy. First of all you have to dissasemble the case, then remove the paper slot. To do this you have to unscrew three or four screws (at least in my c45) that keep the paper slot attached to the printer. After doing this you will see the ink pads, they are at the bottom back of the printer. Mine has four of them with an "L" alike shape.
Clean them with plain water, then let them dry a couple of hours until all the moisture is gone.
I advice you to remove both ink cartidges before doing this because an strange thing happened to me.
After removing the ink pads i cleaned the ink pad container (you'll see the little tube that drains the "waste" ink from the cartidges to the pads) then a couple of hours later i found that the container was full of ink!! confused1.gif . And of course, the ink cartidges were almost empty upset.gif
That happened because i didn't remove the ink cartidges before doing the whole process. I have no idea why that happened but probably by removing them you'll avoid that.
Epson resetter software can be found at http://www.ssclg.com/epsone.shtml (the link to download it is located at the bottom of the page)
One last thing, to reset the waste ink counter you have to go to "Protection Counter" menu and then click "Reset Protection Counter".
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
