Question about Panasonic KX-TG1033S Cordless Phone
How can I change channels on my kx-TCD510AXM cordless phone. I get massive interference caused by my router on the phone line when the router is switched on. Changing channels on the router has no effect. Only switching it off works. Filters are also fine as far as I know. Even with the base on hands free there is interference so it must be at the phone line level. Any ideas how to solve the issue?
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Phone says I am too far away from the base--panasonic kx-tg2356s
unplug the base unit and when you plug it
back in the handset should work
Posted on Feb 07, 2009
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
  • 5524 Answers
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
SOURCE: KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Posted on Oct 23, 2010
HOW DO I CHANGE THE BROADCAST CHANNEL, GETTING LOTS OF STATIC AND INTERFERANCE
The broadcast channel can't be changed according to the units instructions some other electronic device is causing the interference you may have to move the base unit. A PDF file of instructions are here
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCgQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FKXTG1032.pdf&ei=Jl_aVNSkGobAggTGlYHoBg&usg=AFQjCNEKuKWxZUBDTtUXNDQOW8Mn92B2dw&sig2=oBfK0fI1HOBEHWvabQGLpA
Jan 26, 2015 | Panasonic KX-TG1033S Cordless Phone
My wii is showing me the 51031
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Aug 29, 2014 | Video Game Consoles & Games
Aug 23, 2011 | Nintendo Wii Console
I am getting error 51032
Jul 12, 2011 | Nintendo Wii Console
Internet isn't working right. Say error code 51030
Mar 20, 2011 | Nintendo Wii Console
What does error code 51030 mean
Feb 04, 2011 | Nintendo Wii Console
When i try to connect to internet it gives a code 51032. and what is a ssid mean thanks chris.
Nov 21, 2010 | Nintendo Video Game Consoles & Games
What is error code: 51030 and how do i fix it ?
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sep 17, 2010 | Nintendo Wii Console
How can I improve the range and clarity of a Panasonic KX-TG5634 Cordless Phone? The phones that come this system have been placed in different rooms in our home, the main base station has a DSL filter...
Hi.
If you can, turn your wireless router off, as this can cause this type of interferance.
If this improves your telephone problem,try changing the router channell.
Good luck.
Feb 07, 2018 | Panasonic KX-TG2336S Cordless Phone
Interference on cordless Panasonic phone
The wireless signal is most likely your culprit. Wireless-B and Wireless-G signals operate at 2.4GHz frequency, which is the same that many cordless phones use.
Some wireless routers will allow you to change the channel that they broadcast on -- that might help your interference problem slightly, but it probably won't make it go away completely. Your best bet is to keep the cordless phone a good distance away from the computer and wireless router (if not in another room, at least on the other side of the room).
Hope that helps!
Mar 09, 2009 | Panasonic KX TGA271B Cordless Expansion...
Panasonic KX-TG1033S Cordless Phone Logo
221 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
