Artisan800- printer says paper jam but none exist??????
    Guru:
  • 389 Answers
Presence to indication about jam paper is defined sensor. Much often быват so that after extraction of the stuck paper sensor or remains in lifted position, its holds up or he conks or falls out of full tilts. Check all sensors, recall, when this has proceed from what node took out the sheet, most often paper sticks on output and more often there conk the sensors. The Other way no. Good luck
Posted on Sep 16, 2009
When doing two sided printing I always get a paper jam indication when none exists. Single sided is OK.
Likely a small peice of paper stuck in the rollers on the paper flipping side, or a bad sensor.
Dec 29, 2014 | Epson Artisan 837 All-in-one Wifi Inkjet...
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Clp-510 constantly gives paper jam error, although none exists.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If problem still exist then best option to contact Samsung Printers Service Provider, Your problem will be solved,
I hope this solution will be helpful for you
Anymore help, I am here to help
Thanks
Mar 26, 2011 | Samsung CLP-510 Laser Printer
Paper stuck in printer hp 4180
Check for paper jams by removing the access door on the back of the printer. A plastic tab is located on the left side of the access door. Press the tap, then pull the door away from the printer. If a paper jam does exist, clear the jam by pulling the jammed paper out of the printer's rollers. Close the access door and press the "Resume" button on the printer's control panel.
Oct 31, 2010 | Office Equipment & Supplies
false error message / could be due to the dirty rollers or bac=d sensors on the printer. Sometime when printer does not get enough power it might give this erropr message .
Hence also try to change the power source.
Oct 16, 2010 | Samsung CLP-510 Laser Printer
Says paper jam when none exists
Ah, I feel your pain! Been there.
Make sure you are doing a complete inspection on your printer. You may have removed what you thought was causing the jam, but in actuality there may still be a small piece of paper within the paper feed mechanism. Make sure you check both the front and rear (if you have both) doors of your printer.
I would also suggest cleaning the paper rollers (the little rubber looking wheels that move the paper through your printer). They can get dusty and not grasp the paper as well as they originally did.
As for the cartridges slamming, check the plastic strip that connects to the cartridge carriage. It may not be connected properly.
Mar 11, 2010 | HP Photosmart 2575 All-In-One InkJet...
The display says there is a paper jam, but there is none
Sounds like the printer need to be "reset"
Cancel all print jobs.
Disconnect the printer from your computer
Turn power to printer off and unplug it.
wait 1 min, then reconnect printer to your computer.
then plug printer back in and turn it on.
Start your print job over.
Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
Start print job again.
Should the problem still exist contact support at Samsung via the links on their homepage.
Good luck.
Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Printer says paper jam but there is none
Look Inside of each cover on the printer & see if there is a small piece of paper inside. Also, check if there is loose dust from the paper built up by the sensor switches. If none of these work, try flipping the sensor switches manually. Sometimes these get stuck in a particular bad paper jam.
Feb 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
HP 4 printer jam
I dont' think there is a site that exists. If this is a paper jam that occurs every few pages or so...you most likely will need to replace your pickup roller (located up under the machine after removing the cassette
Aug 26, 2008 | HP : HP4 Laserjet Printer
23 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
