Question about Cuisinart DCC-1200 Coffee Maker
Cooffee maker shuts off after start buttom is puched on.one way valve not working,no water getting to heating element
  • 85 Answers
Hello harleyswimmi,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_f5065d2791067928
Nov 13, 2016 | Electrical Supplies
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I fill the Brew and Go with water (ground coffee is in, etc), push start button and then is shuts itself off after about 20 seconds (it makes the gurgling sound like it does at the end of a normal,...
It sounds like the valve [ball?] at the bottom of your reservoir is sticking. That will prevent good water flow into the heating chamber. Hence, the thermostat trips and shuts off the brew element. Try running undiluted vinegar [without coffee in the basket] to see if this cleans the valve. Also try turning the maker upside down over the sink when the cycle stops, to "backwash" the valve with the vinegar. You may have to repeat this several times.
Aug 24, 2017 | Black & Decker Brew N Go DCM18 Coffee...
My coffee maker takes 20 minutes to brew a pot of coffee- extremely slow- I've lost the manual and do not know how to correct this...please help.
The first suggestion is de-calcify as the heating element is probably coated. The following should explain what I mean.
Most likely you have calcium flake deposits clogging the orifice/jet/valve, that restricts the flow of water until heated properly. As the water starts to flow the flakes collect and block the water flow. Periodic cleaning will cure this and prevent damage to the, orifices, jets,valves and heating elements of your machine ( as calcium builds up it tends to insulate the heating element thus requiring more energy/heat to complete the task). Eventually the heating element will over heat and burn out. Periodic cleaning extends the life of the machine plus the added bonus of a better tasting " Cup of JOE".
Most any cleaning preparation designated for a "Mr. Coffee " type machine will do the job. If you want a home remedy 3-4 tablespoons of white distilled vinegar per cup of water ( calculate for the size of your water reservoir ). But please do it outside on the patio, as the vinegar tends to be in competition with the air freshener, and will win.
sincerely,
Doc Michael
Mar 08, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee maker will not start. It is program correctly and acts like it wants to start, but will not.
If your display works then there is probably a problem with your heating element. Without the heating element working properly it will not draw in any water to brew.
Nov 08, 2010 | Krups FME4 Coffee Maker
Won't pull up water from the reservior to the coffee carafe.
Your heating element is plugged. The element gets water but not enough to build up enough pressure to push the water up to the drip head, when that happens what it will do is steam a little, overheat and shut off. I pulled a wire through my element got a lot of **** out now it works like new.
Jul 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
161 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
